Thread: Auto Gearbox Contamination? REcall/Rework?
    Apr 2012
    Swindon
    Default Auto Gearbox Contamination? REcall/Rework?
    I've been trying to get my head around the issues with auto boxes getting wrecked due to water contamination due to failed radiator seals.
    I've read that a production modification was made to rectify this fault from a certain VIN number. Mine was built before this.
    Has there been/is there a recall or modification that Vx perform on earlier cars?
    I've not had the car long, but it has previously been serviced by Vx dealers, so if there is one, should it have been done????
    Cheers, Nez
    Apr 2012
    Swindon
    Bump
    Jun 2011
    Northumberland
    Vehicle : Vectra 1.9 cdti 16v (150)
    Trim : elite
    Not much help to you but I also asked this question on the thread "AutoBox Knowledge AF40?"
    "From other research I suspect that my 56 Reg 1.9 Cdti (2007 reg) would have the modifications to the standard cooler in the rad. Is there someway of proving this with Vin No's? One of the threads below also mentions a 'glycol' test. The coolant in the expansion tank has no sign of oil in at all."
    I did find a thread whch may be interesting
    Signum Water in Gearbox Court Case v Motor Trader
    regars Neil
    Apr 2012
    Swindon
    Thanks for the link
    Nez
  1. Auto Gearbox - Can you prevent Water Contamination?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 3rd December 2012, 15:17
  2. Auto Gearbox
    By viper8 in forum Engine & Drivetrain
    Last Post: 7th March 2012, 21:12
  3. auto gearbox oil
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2011, 08:42
  4. Gearbox contamination
    By topaz in forum Engine & Drivetrain
    Last Post: 25th January 2010, 23:46
  5. Gearbox Coolant contamination
    By Will Glenn in forum Engine & Drivetrain
    Last Post: 2nd July 2008, 18:23
