Results 1 to 10 of 19
Thread: Turned ignition key, no power...
    Regular Member izonoky's Avatar
    Aug 2007
    London
    Default Turned ignition key, no power...
    Jumped into veccy (2.2 Direct '06), turned ignition key, engine half turned over then went silent. Dash lights flickering, cabin light flickering, (EMS light flickering), could hear a clicking noise coming from the back then all electrical power vanished (no lights on dash), wont turn over. can't lock car.
    Didn't have time to open the bonnet and check for anything, hijacked the wife's toyota and dashed off to work.
    No warning lights or symptoms the day before.
    Unblocked a drainage channel (just beneath the windscreen) four weeks earlier, as I'd had some water get in and seep under the carpet; there's still some water under the carpet on the rear passenger side, was wondering if this might be a factor.
    Suspect a failed alternator... (62000K on the clock)
    Any suggestions and possible repair costs?
    Jan 2012
    leicester
    hi izonoky sounds like may be the alternator i got a recon £90 and fited it my self took me 1hr 45mins but have the batt tested first thats the cheapest and easy thing to do
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Flat battery
    Jump it and see how it goes
    ---Sent from my iPhone 4 using Forum Runner.
    11 Post(s)
    Quote Originally Posted by tony-1977 View Post
    Flat battery
    Jump it and see how it goes .
    Then put the battery on charge overnight.
    Aug 2007
    London
    Good call Tony. Flat battery it was. Jump-started it this afternoon, engine ticks over nicely but shuts off after 10-15mins. Battery voltage jumping up and down, reckon it's best just to buy a new one (about £90). But mightily relieved it's nothing more serious than that. Had already called the stealer's in anticipation.
    Dave, I don't have a battery charger, so I'm weighing up the option of buying one versus a brand new battery...
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    If it shuts down like that, with the voltage jumping up and down, it's deffo the alternator that's shafted
    Aug 2007
    London
    Ouch! Thought I'd dodged a bullet, looks like I should just get it over to the stealer's and get it over with.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    What voltage were you getting exactly? Should be at least 14 (14.5 ideally) at idle with engine running and no other electrics on (blower, lights, etc).
    Try Euro Car Parts for an alternator, helluva lolt cheaper than the main dealers
    Aug 2007
    London
    Getting 14.5v then it dips to 14/13.8 or.7 and lower before rising for a few seconds then dipping again.
    Never fitted an alternator, if I can get the part cheap I might give it a shot.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Deffo sounds like the alternator. Have you driven it a few miles since starting it up?
  1. Would these cause cutout? as though ignition been turned off
    By Chuddy in forum Engine & Drivetrain
    Last Post: 29th January 2010, 22:09
  2. Vectra 3.2 05 Gsi clicking noise when ignition turned on/off
    By bignew in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2009, 19:36
  3. Series of beeps whrn the ignition is turned on
    By DeathStar in forum Vectra C / Signum Troubleshooting
    Last Post: 12th April 2009, 19:54
  4. Ignition power
    By carl bear in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2007, 15:14
  5. Taking Power Outlets off Ignition?
    By chrisschild in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2006, 19:33
vectra no power from ignition
vectra c 1.8 no power from ignition
