Thread: VXR Gear stick - HELP NEEDED!!
    Regular Member simmo3187's Avatar
    Jul 2010
    North Wales/North West Border
    Engine : 3.0 V6 CDTI
    Default VXR Gear stick - HELP NEEDED!!
    Right as some of you may know I bought a vxr centre console off ebay
    Advertised as having a vxr gear stick complete!!
    This is the bit I have had in the post
    My question is...
    Is this enough to be able to fit this to my vec c or am I supposed to have some other bits too
    East Midlands - Regional Organiser new boy's Avatar
    Nov 2010
    lincs
    48 Post(s)
    Vehicle : BTCC Edtion
    Trim : SRI LEATHER
    Engine : 2.0 TURBO
    Year : 07
    not 100% but i think you have to have the gear linkage bit to
    Jul 2011
    UK
    Year : 06
    As said u need the linkage it's a stick with a ball connection looks like the seller got lazy and just undone the knob u might be able to do it t ya vectra one see if u got same kind clip think u have and it's the same so u should be able to disconnect ur vectra knob from the top and slot the Vxr one on if not send it my way
    Jul 2010
    ok mate thanks
    I've just emailed the guy now so will see what the response is
    Is the vxr one a shorter throw?
    Also will I need to use the VXR gaitor?
    Jul 2011
    UK
    Year : 06
    It seems to be I've got Astra one not Vxr and seems it best to use the gator but swap the base the white plastic bit and use double sided tape pretty sure the vectra on will unclip like the Vxr one u have
    Regular Member 130786howe's Avatar
    Nov 2010
    wales
    hi mate i had myn today pm your number il give you a buzz and tell you how i got on and help you if i can i new that sneaky b*****trd he only had to undo 4 torx
  1. Where can I get this gear stick?
    By John LE in forum Styling
    Last Post: 30th April 2012, 14:14
  2. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  3. gear stick
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2011, 16:32
  4. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
