Results 1 to 10 of 14
Thread: Cylinder 1 Missfire
    Regular Member JaceyBoy's Avatar
    Apr 2012
    Bournemouth
    Default Cylinder 1 Missfire
    Guys, got my car diagnosed with this problem today, thought it was the dreaded fuel pump but it seems it could be plugs, leads or coil pack, is this a common fault on the 2.2 Direct petrol signum?, how do I know which one to replace?
    Also they reset the fault and the car seems fine again, weird, but I havent put the engine under high revs...
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    its likely to fail again at high revs then.. cylinder one is nearest the belts
    Apr 2012
    Bournemouth
    Quote Originally Posted by Caveman_nige View Post
    Thanks for the reply but what do I replace?
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    Trim : Exclusive
    Engine : 18VVT Z18XER
    Mileage : 130k
    I had a misfire in cylinder 4 on my 1.8vvt a few weeks ago, turned out to be the coilpack
    Regular Member DTi Elite's Avatar
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    before they dismissed the fuel pump did they run live data to see what the fuel pressure is actually doing at the higher end of the rev range ?
    Apr 2012
    Bournemouth
    They didnt dismiss the fuel pump, but as it was cylinder 1 missfire we assumed it was plugs or coil pack...
    May 2012
    county durham
    Mileage : 145k
    I would try running the live data & see exactly where the fuel pressure is , this may well not be it but needs looking at anyway .
    Apr 2012
    Bournemouth
    Thought I would let you guys know that I replaced the plugs (cheapest option first) and the car is running like a dream again
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Good news and the cheapest option. Keep an eye on it though as a failing coil will kill a spark plug.
    Apr 2012
    Bournemouth
    Hmmm just went out and booted in 2nd and it cut again, could it be coil pack failure?
  1. 2.8 Missfire
    By Ziggy in forum Engine & Drivetrain
    Last Post: 27th June 2012, 20:07
  2. Missfire!
    By R1-RAB in forum Engine & Drivetrain
    Last Post: 6th February 2010, 21:05
  3. missfire
    By robbie1944 in forum Engine & Drivetrain
    Last Post: 10th June 2009, 20:05
  4. missfire 2.2 dti sxi
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2009, 22:55
  5. 1.8 missfire.
    By 16vVec in forum Engine & Drivetrain
    Last Post: 19th September 2008, 20:02
