Results 1 to 10 of 11
Thread: injector no4 leaking.need advice asap
    Apr 2012
    ayr
    Default injector no4 leaking.need advice asap
    hi there.i recently sold my old 53 plate 2.0 dti and bought a 1.9 cdti sri 2005.its been great and ive done 2000 mls no prob.today while cleaning car i removed the engine cover to clean and found what can only be described as a black blob around the 4rth injector.i immediatly run the car to local garage who didnt want to even touch the car.i called the guy i bought it from and he told me that this temp fix was done before he bought the car 3 years ago and its been running like this for years.well ive been trying to get prices from good garages and there all painting terrible pictures.saying the injector might be seized.it might break when trying to remove.one garage even told me to just leave it alone.i love the car and just want it fixed.what do i do?any advice would be great as i feel terrible.never had any problems like this before.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    it will more than likely be chuffing at idle & maybe even leaking a bit of smoke , so it needs sorting as you rightly say .
    it could well be tight in there but a couple of days patience & some searing may see it come out , will need to be soaked with something to loosen the tar/carbon .
    Apr 2012
    ayr
    thanks for the quick reply.got a ring back from local vx dealer.they quoted me £62 for an hour labour and fitting new copper washer/seal.phoned a few local garages and they wanted a min of 4 hours labour.i just hope that it comes out easy and that the new seal fixes my problem.knowing my luck i will put it in and my injector will break when being removed.i have not got good luck when dealing with main dealers.anyway its booked in for monday morning.fingers crossed.
    Apr 2012
    ayr
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    blimey that looks a right mess
    Apr 2012
    ayr
    gives you an idea of how im feeling doesnt it?i have a feeling that this mess will take more than an hour to fix.what do you think.?
    Are you VXR Enough
    13 Post(s)
    i think you could be right there fella it does look like its hiding something
    Apr 2012
    ayr
    injector came out with not much hassle.cleaned up and looked good.removed seal.cleaned seat.refitted new seal with cleaned injector.run car for few miles and to cut long story short i still havent sealed injector propperly,anybody got any advice on how to seal injector properly?also should injector 4 be lower in the head than other 3 injectors?please help.
    Engine : 1.9 CDTi
    How did you clean the seat as we have a tool that does it as it needs to be flat and 100% free of carbon to get a good seal.
    This is the one we use: http://www.ebay.co.uk/itm/Sealey-Too...item20c4ce42ef
    Apr 2012
    ayr
    hi lee the guy in the garage used a long tube thing that a brush came out the bottom.i suspect this is my problem.also i think the last owner might have used the tool you listed a bit too much as my injector sits lower than the others.im now waiting on diesel specialist calling me back to arrange to see the car.im now pricing a new head just incase it comes to that,could kick myself for not checking under the enigne cover before i bought the car.feel sick,
  1. injector leaking
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2012, 13:10
  2. Damn car! (150 cdti injector leaking)
    By John LE in forum Engine & Drivetrain
    Last Post: 29th February 2012, 18:46
  3. petrol injector leaking!!!!
    By mollers34 in forum Engine & Drivetrain
    Last Post: 30th November 2011, 06:10
  4. noisy and leaking injector?
    By leeky1 in forum Engine & Drivetrain
    Last Post: 15th May 2011, 23:09
  5. 2005 Vectra 1900 CDTi 150 Injector Leaking
    By MXB74 in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 23:17
vectra 1.9 cdti leaky injectors www.vectra-c.com
