Thread: wet carpets in passenger footwell
    Full Member les287's Avatar
    Mar 2011
    wirral
    Default wet carpets in passenger footwell
    ok, i know about the rubber bung blocking and the scuttle tray filling with water. mine has the bung removed so ther is no chance of it becoming blocked. but every time it rains the passenger footwell gets soaked. i removed the pollen filter and the top of the cavity the fan sits in is wet aswell (so the water must be coming in from above that. the only thing i can think of is the seal around the bottom of the wind screen). is it just slotted into place or bonded?
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Hi Les, have a look at my post on page 16:
    http://www.vectra-c.com/forum/showth...lateley/page16
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    i think this may help a member posted this
    Water leaking into footwells - new solution
    After a few months of going crazy with my vectra c leaking rain water into both footwells after every downpour i finally found the problem:
    THE SYMPTOMS:
    When my car had been standing in rain,water seem to be pooling somewhere behind the dash then leaking into both footwells when driving off. I could hear water sloshing from side to side as i drove. Took both "L" shaped panels off in both footwells to expose ecu/wiring and water could be seen pouring down both sides behind soundproofing, eventually seeping under carpets and soaking them through. Before I removed these panels you can't notice the leak as it cunningly leaks hidden to below carpets.
    THE SOLUTION:
    Most people told me it was common for the vectra to leak through the pollen filter into heaters and through pipes into footwells caused by blocked drains in scuttle panel - this wasn't an issue in mine as it drained how it should do!
    Next i decided to have a windsreen "accident" thinking a seal may have gone, got the screen replaced but made no difference!
    Then i noticed this gap after removing wipers and scuttle panel top cover. Just below where this panel clips to windscreen there is a gap where windscreen ends and bodywork starts - only a few mm wide but runs width of screen and opens out slightly towards edges. Anyway seems water runs down edges of windscreen and can enter this void, then sit patiently there until u drive off and somehow enter the footwells.
    All i did was fill this gap in with silicon sealant from edge to edge to make it water tight and TA-DAH not leaked since!!!!
    Mar 2011
    wirral
    i'll take a look over the w/end (if it stops raining).
    Full Member Niall83's Avatar
    Nov 2009
    Belfast
    It's usually the drain under the pollen filter being blocked that causes that.
    AirBox Mod-Angel Eye head lights-HID 5000k-Colour coded grill-GID to CID-Auto Dim rear view Mirror, Rear Parking Sensors, Signum Fog surrounds, 19" Audi A5 rep Alloys, Eibach 30mm Pro-kit Lowering Springs.
    Mar 2011
    wirral
    just had the pollen filter holder out of the car. the foam seal around the hole that locates onto the bulkhead has perished. sorted that out with some silicone sealant. (looking into getting some bits of plastic to raise the lip on thefront of the pollen filter holder, to make a crude splash guard for when the rain water is sloshing around in the scuttle tray).
  1. water in passenger footwell (help)
    By scottwales in forum General Motoring Chat
    Last Post: 5th July 2012, 07:26
  2. Wet passenger footwell
    By aaruck in forum Engine & Drivetrain
    Last Post: 2nd October 2010, 11:13
  3. wet passenger footwell
    By n8sby in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2010, 20:40
  4. Passenger footwell wet in the Vec-B, HELP!
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2010, 22:22
  5. wet passenger footwell
    By al21784 in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2007, 23:42
