Thread: Signum 1.9 cdti 150 Blue Smoke
    New Member Kyletasker's Avatar
    Jul 2012
    Chester
    Default Signum 1.9 cdti 150 Blue Smoke
    Hey everyone having problems when I start my Siggy first thing in the mornings it can take a while to start and when it does there's alot of blue smoke and car rattles like its trying to stall but doesn't???
    After running the car for severely miles the blue smoke goes away and tick over is about 80% normal (still rattles slightly)
    Also there is no power in the car until it hits about 2500rpm when the Turbo kicks in and then its like a missle.
    Anybody know problems what could be causing these issues and easy/ cheap fixies???
    Spoke to Paul Vec C and he's advised on a couple of issues also!
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Its worth checking the glow plugs are ok first & they need to be a good make not cheapies really, Secondly carefully remove the common rail sensor/s clean with brake fluid take care not to cross thread or over-tighten just nip back up, The blue smoke & chugging is more common in the cdti's than you think, Mainly unsolved by most but it appears the dmf is a common cause also, It becomes off balance when worn & tends to throw the engine running off balance from start up & on tick-over.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    had an astra at work doing the same & it was a duff EGR valve , no fault codes stored for EGR valve although if my memory serves me well it had p2279 intake leak detected .
    Jul 2012
    Chester
    Cheers guys thinking it was the egr or swirl flaps and I've had my clutch and dmf changed last month with new manifold and Turbo under warranty from the garage I bought it from (there gutted with the ammount of money its cost lol) but there stuck at a dead end now with the problems I'm having now and mentioned egr and swirlflaps but they haven't got a clue ("were not mechanics") they quoted! They've got it back at the mo trying to fix problems but it'll come back still broke guaranteed.
    I'll try doing the egr myself with the how guide but not very mechanical minded
  1. SRI CDTI 150 Blue smoke on startup
    By sukyb in forum Engine & Drivetrain
    Last Post: 15th February 2011, 13:47
  2. SRI CDTI Blue smoke on startup
    Last Post: 8th February 2011, 12:01
  3. blue smoke on 1.9 cdti 150
    By big nath in forum Engine & Drivetrain
    Last Post: 26th November 2010, 09:44
  4. blue smoke 3.0 cdti signum help!!!
    By MARTIN KANE in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2010, 21:03
  5. Blue Smoke on Startup SRi CDTI 16v Help !
    By Tim in forum Engine & Drivetrain
    Last Post: 22nd December 2009, 19:09
vectra cdti blue smoke site:www.vectra-c.com
