Results 1 to 10 of 19
Thread: Colour screen help
    Regular Member larrygroke's Avatar
    Feb 2011
    Plymouth
    Vehicle : vectra c
    Trim : Exlusive
    Default Colour screen help
    I am wanting to put a colour screen in instead of the black and orange one i know that it will only come up red and white however i don't mind that as i have a mod up my sleeve which i hope will impress can i just put any one into my car i have a facelift model 07 reg also would i need to change the wiring at the back?
    Jul 2011
    UK
    Year : 06
    Ul need a cd70 if u don't have a aftermarket head unit
    Feb 2011
    Plymouth
    Vehicle : vectra c
    Trim : Exlusive
    i have an aftermarket head unit looked on the bay and none for sale on their own any other places i could look?
    Jul 2011
    UK
    Year : 06
    I've been looking for a while and none around maybe a breakers yard will have one
    Regular Member stephen_brady's Avatar
    Jan 2012
    N.Ireland
    I may have a colour screen going spare. My Hu has packed in and it looks more worthwhile to buy both together... Pm me if either are interested.
    Feb 2011
    Plymouth
    Vehicle : vectra c
    Trim : Exlusive
    Stephen Just PM u
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Hang On Stephen - Are you sure that your Head-unit has packed in? - or is it that you have not wired up the display connector yet? - I have repeated this for both of you below.
    Also to the O/P - If you are fitting an aftermarket head-unit, then you will NOT need a CD70 to go with the display, and it should not require any programming, as it will act as if the head-unit is permanently switched off.
    You would however need to ensure that you have the scrollers on your steering wheel to work the BC functions on the display, and to clear any warning messages.
    Assuming that the Display has BC and possibly Check control fitted.
    The display will come up coloured, not just red and white, this will change significantly when you turn on your lights.
    As said in all my retro-fit threads, you MUST ensure that you have 2 brown wires in pins 1 and 2 of the display,
    and 2 red wires in pins 3 and 5 for the display to work properly.
    If you only have onee of each wires, then you would need to -
    link pin 1 to pin 2, and
    link pin 3 to pin 5.
    I hope that helps both of you...
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    To show the difference between day colours and night colours
    day colours first - typical check control warning
    then
    night colours - accessing test-mode pages.
    Feb 2011
    Plymouth
    Vehicle : vectra c
    Trim : Exlusive
    Fantastic! i have a aftermarket head unit fitted i have all the scrollers just need to find one unless stephen is gonna sell his thank you
    Jan 2012
    N.Ireland
    @ Robsey. Hopping it is the HU. I added the additional wires using the equipment from a donor loom and connector which was really good advice BTW, and still nothing. Following from your advice i.e. with the steering controls and all working, it seems terminal.
    I'm meeting a few of the other Fella's from the NI region next weekend, so I might ask one of them to pop the CD70 in their car first before I sell, I PM'd you about this bit Larrygroke, so should know by the end of the month.
    @Marc, I tried to PM you back fella but you're inbox is full.
  1. For Sale: CID Screen. (Colour Screen)
    By jodiexii in forum Parts for sale
    Last Post: 6th May 2013, 19:22
  2. Colour screen
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2012, 13:53
