Results 1 to 10 of 11
Thread: water in passenger footwell (help)
    Regular Member scottwales's Avatar
    Dec 2010
    Ayrshire Scotland
    Default water in passenger footwell (help)
    Well it happened went out to car this morning and theres a puddle in the passenger side footwell.
    Car hasn't moved in a couple of days so checked the scuttle panel and the plug was blocked .
    Unblocked it and cleared all the crap out of it, But what else should I be checking? should i just change my pollen filter anyway?
    any help would be great. hope my blower isn't kaputt.
    Regular Member John Bishop's Avatar
    Oct 2010
    Change filter as its probably soaking, get as much water out and drive round with heaters on for footwell for a few days. Also check drain on drivers side too
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    Dec 2010
    Ayrshire Scotland
    Thanks didn't realise there was 1 on drivers side too ill do that 1st thing
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    you might find that your heater will start to squeak i hope it does not
    make sure your heater settings all work
    normally the water damages the resistor pack in heater
    if you lose heater settings 1 2 3 your need a resistor pack or sometimes a new relay
    i hope you dont have these problems above
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    Quote Originally Posted by scottwales View Post
    its by the wiper linkage
    Dec 2010
    Ayrshire Scotland
    Had the heaters on full while driving around today and thankfully they seemed ok hope they stau like that, silly mistake to make i will be checking the scuttle weekly from now on. thanks for the advice
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    just incase you have any problems here is some useful info for you
    http://www.vectra-c.com/forum/showth...esistor%20pack
    Dec 2010
    Ayrshire Scotland
    cheers that could be useful although i hope not
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    ive been through it before i hope you dont have any problems
    heater resistor broke causing only heater 4 to work only
    squeaky heater
    new pollen filter
    just post up on here if you want more info
    its very common on here the scuttle tray getting blocked
  1. water in passenger footwell
    By brynsueg in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2013, 21:25
  2. water in passenger footwell
    By les287 in forum Bodywork & Interior
    Last Post: 10th October 2012, 21:23
  3. Could water in the passenger footwell be the cause of all my problems??
    By orangepeeleo in forum Vectra C / Signum Troubleshooting
    Last Post: 4th April 2010, 00:04
  4. Water in (rear) passenger footwell
    By shoeless79 in forum Bodywork & Interior
    Last Post: 19th March 2010, 00:57
  5. water in passenger footwell
    By Task in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2009, 16:09
