Thread: 2.2 direct fuel pump failure.will i ever get to the bottom of this?
    Jun 2009
    Middlesex
    confused 2.2 direct fuel pump failure.will i ever get to the bottom of this?
    My (04 reg) Vectra 2.2 Direct has yet another failed Fuel Pump.Pump & Regulator replaced 3 years ago.Tech 2 investigation at Vauxhall say problem is with Fuel Pump again this time.VX would pay nothing towards cost of replacement last time and again refuse to pay anything towards it this time.They say the problem is with the manufacturers of the pump.
    I do not have the money to pay for replacement of the pump myself.Will a new pump solve the problem anyway.VX did do a recall on the Pressure Regulator,why not the pump.
    Can anyone give me your views on this problem?
    Many Thanks.
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    There is a revised pump mate it's a conti one and the fpmsl was recalled they never did fuel pumps it would cost then to much and the answer to ya question is yes it 99.9 percent ya pump I would say
    Jun 2009
    Middlesex
    I,m told that when i had both the Fuel Pressure Regulator and the Fuel Pump replaced 3 years ago the Pressure Regulator was not a modified type and that has caused the pump to fail a 2nd time.I have had the Pressure Regulator replaced 2 months ago i,m told a modified type with a white dot on it.I'm told i need a new pump.The pump i have fitted at the moment is a Siemans type.Can i confirm the manufacturing name of the new pumps.
    Can anyone tell me if anyone is still having problems or am i the only one.
    Thanks Dobs
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    Believe the newer version is by Continental, but these aren't immune to problems.
    Jun 2009
    Middlesex
    Is anyone but me still having problems with the fuel pump on th 2.2 Direct?
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    just had a signum in at work that was playing up , would run for a good while & then it would cut out without warning , ran live data & the rail pressure was under 1000kpa at idel when desired pressure was approx 3800kpa , at approx 3000 rpm the pressure was approx 10,000 kpa when desired was approx 4000 kpa .
    my reckoning was failed regulator that was probably stuck half open , replaced it & hey presto its sorted .
    Jun 2009
    Middlesex
    Paid to have both pressure regulator and fuel pump replaced just under 3 years ago and now pump has failed again and Vauxhall will pay nothing towards replacement of these items when clearly these items are not fit for purpose.Any idea's what i should do next?
    Jun 2009
    Middlesex
    Bump
  1. Vectra 2.0DTi fuel pump failure
    By Davyturner in forum Engine & Drivetrain
    Last Post: 29th January 2013, 17:33
  2. Options for DTi fuel injection pump failure
    By circushead in forum Engine & Drivetrain
    Last Post: 21st November 2010, 12:00
  3. Vectra C direct 2.2i fuel pump failure
    By davidu in forum Introduce yourself.
    Last Post: 19th September 2010, 23:58
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
  5. 1.9 CDTI 150 Fuel pump failure...help!
    By sri150 in forum Engine & Drivetrain
    Last Post: 13th November 2007, 15:19
vectra 2.2 direct fuel pump
