Thread: Lights on/Doors open/ warning buzzer
    Jun 2012
    Essex
    confused Lights on/Doors open/ warning buzzer
    Hi,
    Hope someone can help me with this one. Have a May 2005 pre face lift 1.9CDTI SRI hatchback 8 valve 120.
    No buzzer alarm sounding if lights left on/door open/key left in ignition.
    Should my model have such an alarm as handbook is unclear and if so which fusebox will I find the relevant fuse in and if possible the number of it.
    Many Thanks,
    Rob (new member this month)
    Regular Member John Bishop's Avatar
    Oct 2010
    Remember my wife had a corsa (don't laugh) but it didn't have one. So it may be that in days gone by they were not standard. I remember having a cav that didn't have one too when I think about it.
    11 Post(s)
    Quote Originally Posted by Rob1966 View Post
    Pretty sure all models came with it as standard. Even my Dad's base model 51 reg Astra-G had a key left in igntion warning and headlights left on alarm.
    Do your indicators "tick tock" when used?
    Do you get a beep when putting the parking lights on? (with key out the ignition switch the indicator stalk to the left or right)
    When switching off the wipers, do you hear a faint electronic sounding click?
    IF you lightly pull on the handbrake while doing more than 10 mph, do you get a warning noise?
    If no to any of the above, then the sounder for all of these (including lights on, key in ignition, etc) isn't working.
    Jun 2012
    Essex
    Thanks for your replies John and Dave, any idea if this is an easy DIY fix, for example a fuse like I first thought or is it more involved to sort it out,
    Cheers, Rob
    Oct 2010
    Remember when asking about the wifes corsa. Vauxhall said they could fit it. I presume its is some plug in module
    11 Post(s)
    I could be wrong, but I think it's part of the CIM unit under the steering wheel.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Does the door open light show on the dash with the driver's door open?
    Jun 2012
    Essex
    Hi John, No, no warning lights for door open , lights on, no seatbelt etc
    11 Post(s)
    Never got an answer to part of my other question I put to you:
    Jun 2012
    Essex
    Apologies Dave,
    Tick tock-no
    No beep when putting parking lights on
    No click when turning off wipers
    No warning noise re handbrake
    And just to clarify, yes the red door open light does come on in the display under the tach when I open it but no other lights flashing or otherwise by way of alarms on dash
    Thanks,
    Rob
  1. Need help big time! Doors won't open!
    By pistonpete in forum Bodywork & Interior
    Last Post: 22nd October 2012, 23:11
  2. Seatbelt warning buzzer
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2012, 14:06
  3. seat belt warning buzzer
    By mabski in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2010, 10:40
  4. deactivate the warning buzzer on vectra C
    By mustangboy in forum Bodywork & Interior
    Last Post: 2nd January 2010, 11:58
  5. Headlight/Door warning buzzer
    By akulla in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2007, 21:11
vauxhall zafira sounder for lights not working
astra door open warning light
astra problem with door open light and alarm
buzzer no vectra
do vauxhall corsas beep when lights left on
corsa key buzzer not working
vectra warning buzzer not working
buzzer vectra c
how to turn iff warning buzzer in vauxhaul corsa
corsa no lights left on warning alarm
corsa 2011 door open warning
fuse for warning buzzer corsa c
warning buzzer stays on corsa c
light buzzer stays on when doors close on corsa c
warning buzzer location 2007 astra
where is the lights left on alarm on a vauxhall vectra
