Thread: Led/smd question
    Regular Member MACVVT's Avatar
    May 2011
    fife,scotland
    Vehicle : vectra c
    Trim : sri
    Engine : 1.8 vvt (XE18XER)
    Mileage : 28,000
    Default Led/smd question
    fitted smd/led 501's to all internal lights back & front of my vec had problems with rear passenger lights but are working now, did the same to my sons astra sri xp, but the rear lights will not work with led/smd 501's ' they work in front map reading lamps.
    tried 6 or 7 bulbs but they will not work,used the same ones in my wifes motor and every bulb works.any ideas why they do not work.
    Mac
    Jul 2011
    UK
    Year : 06
    Quote Originally Posted by MACVVT
    Mac
    Had this on my vectra check the connection on the holder the bulb goes into is alright
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    Obvious thing is they were in backwards... but that's too simple and far too coincidental for 7 bulbs?
    Mar 2012
    Walsall
    blown a fuse whilst pushing them in?
    May 2011
    fife,scotland
    Vehicle : vectra c
    Trim : sri
    Mileage : 28,000
    thanks guys , bulbs tried both ways - + , sons car is only 8 months old , original bulbs work ok. heres other one the festoon bulb for boot light will not work with led/smd, but works in glove box ???????? no figure.
    Jul 2011
    UK
    Year : 06
    Might be possible that the car don't like too many LEDs
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    had the same on my rear light and i had pushed the connectors together when putting bulb in so no bulb worked doh all sorted and working now tho
    May 2011
    fife,scotland
    Vehicle : vectra c
    Trim : sri
    Mileage : 28,000
    turns out unit is faulty, took my unit and connected into my sons car and bingo all good ,vauxhall dealer says original bulbs work ,no replace under warranty , new unit ordered for lmf.
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    I have a similar problem, smd 501 bulbs in front map lights, go to put them in the rear and the lot goes off, remove the rears and all is fine again
  1. GSI Inner tie rod question.
    By Lee_gsi in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 19:46
  2. question about hid
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2011, 23:15
  3. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  4. Just a question...!
    By Maxim007 in forum Styling
    Last Post: 26th January 2010, 20:12
  5. BSR question
    By soulman in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 22:55
