Thread: Aerial Base
    Barrow In Furness, Cumbria
    Default Aerial Base
    Does anyone know how to tighten the aerial base on a 2008 Vectra? Mine's started wobbling!
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    yes, drop the rear portion of the headlining to access the nut which secures the base and tighten it, think its 17mm. When I changed mine for a DAB aerial its wasn't very tight at all!
    Thanks. How do you drop the headlining? Does it it just unclip?
    Full Member coldo's Avatar
    Scotland
    This how to should help... it's for fitting a rear light but you can get at the Aireal base doing the same thing...
    http://www.vectra-c.com/forum/showth...t-Installation
    Oh... consider loosening it first and putting some black sealent on the base and tightening it up... That should ensure the base is tight and wont lett water in...
    Thanks - the rubber base is fine though. The whole aerial assembly was replaced by VX last year. Guessing that's why it's now loose cos the monkeys didn't tighten it properly!
  1. aerial and base
    By paul.sessions in forum Parts for sale
    Last Post: 21st November 2010, 10:16
  2. Aerial Base
    By tubby in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2009, 21:31
