Thread: Pulling to the right.
    Jun 2011
    wolverhampton
    Default Pulling to the right.
    Hi guys. Had car two months now and always noticed a little pull to the right. Tyres just been replaced by myself and am gona do an alignment. Just wondered what is adjustable on my 2.2 dti Sri. Camber and toe on front and nothing on the rear is what I'm thinking you are all going to say.
    Many thanks andy
    Nottinghamshire
    Got a surprise for you then...
    Toe and camber are adjustable on both front and rear. The rear is adjusted first to get a 'centre line' through the car then the front is adjusted based on this. Hope your rear adjustment bolts haven't seized...
    Regular Member John Bishop's Avatar
    Oct 2010
    Had to have mine done as the rears were droning heavily and tyres were badly feathered
    Regular Member 130786howe's Avatar
    Nov 2010
    wales
    make sure you check wishbone arms first before you go messing with camber check for play if you havnt already done this
    Jun 2011
    wolverhampton
    Is the front adjusted via the lower strut mounting point to the hub? Will I need any special bolts or are they already fitted with cam type washers if needed. Or just elongated holes then very tight bolts for both front and rear. Cheers for the fast depots guys
    May 2012
    Near Grmsby
    Sorry, I saw the thread title and thought I would join in as I'm sick of lefty tree huggers selling this great country down the p/correct river
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    Quote Originally Posted by rimotu66 View Post
    i take it you have had a refund on the car and now you are drinking beer lol
    Nov 2010
    East Midlands
    Trim : design
    Is it pulling to the right when driving along or when you brake - just wondering if it could be a brake issue ie caliper
    Jul 2009
    Yorkshire
    I appreciate that this post is now 3 weeks old, but I thought I would share an experience - it might help someone else with similar issues in the future...
    I had 2x new front tyres fitted recently, after which my car pulled to the right. I swapped the front tyres around and it then pulled to the left - so I swapped them back again and (you guessed it) they pulled to the right again. I took the car back to the tyre fitters and they told me it was the tracking as tyres are never faulty - but I wasn't convinced for two reasons - firstly, the old Goodyear NCT tyres were worn equally across the tread when removed, and secondly, the steering wheel was perfectly central and the car never pulled prior to the new tyres being fitted. After lots of disagreeing with the tyre centre manager, he replaced the right tyre (reluctantly!) and it solved the problem straight away. It turned out to be a faulty tyre casing all along! The car has been perfectly fine since!! So the moral of the story is simple - Tyres CAN be faulty when new, and some tyre centre managers sing a good song but actual DON'T know their asses from their elbows!!
    Regular Member se4's Avatar
    Aug 2010
    wales
  1. Car pulling to the right :(
    By !tf in forum Suspension, Wheels & Brakes
    Last Post: 5th December 2011, 19:18
  2. pulling to the left
    By monty2000 in forum Suspension, Wheels & Brakes
    Last Post: 29th November 2010, 23:17
  3. Pulling All Over? please help
    By stubby1988 in forum Suspension, Wheels & Brakes
    Last Post: 25th May 2010, 13:05
  4. car pulling in 2nd
    By Morephun in forum Engine & Drivetrain
    Last Post: 18th February 2009, 02:12
  5. Pulling Out Of The Pod...
    By Mark The Cabby in forum General Chat
    Last Post: 6th June 2006, 23:14
