Results 1 to 10 of 19
Thread: Do injectors need programming in?
    Regular Member will-crowe's Avatar
    Jun 2012
    Norwich
    Default Do injectors need programming in?
    Hi all. As a few people have read on here iv been having a fault of blue smoke on cold start up on my 1.9 cdti 150 sri. after owning it 3 months its been in 8 times for injectors. 5 refurbishments on 1 injector and 2 replacements and still the injectors are reading odd on the tech 2 but not enough to qualify a replacement. the garage who diognosed it and who i bought it off say injectors dont have to be programmed in but a friend said they do. Also vauxhall and another garage have had the car and diognose injectors being the problem please can some shed some light on this so i can get it sorted as iv only have the car for 1 month, the other 2 its been in the garage
    many thanks
    will
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    Simply yes. Tech 2 or vaux.com will do the job
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Yes
    Jun 2012
    Norwich
    awesome guys thanks alot. i will get it done. big thanks
    will
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    They absolutly have to be programmed. the car will run if they are not but not correctly.
    Get them programmed (number on top of the injector) and re-evaluate the issue then....
    Jun 2012
    Norwich
    i spoke to the garage who i bought it off and who are also carrying out the work and they said to me before they dont need to be so i kicked up a stink and said yes they do, they replied ' we have done them' but im unsure how can i tell and how much does it cost if i was to take it to another garage and get it done
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    have you spoken to vauxhall themselves? and it sounds like this garage is giving you the run around fella as the others have said they do need to be programmed to the car
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    get onto them & get this sorted sharpish , once you have had the car for 3 months they may well tell you to go away as thats about as far as your rights go with a second hand car .
    injectors need to be programmed , so tell them that you will be wanting to return the car for full refund as it is not fit for purpose , unless they have it sorted properly .
    dunfermline
    yes they need coded mines melted number 3 piston thanks to previous owner changing injectors an not programming
    Engine : 1.9 CDTi
    If you have access to Tech2 or other type software you can go into the 'Programming injector' section of the Tech2 or type software and check the serial numbers of the injectors that are listed match what are in the engine.
  1. CIM Programming
    Last Post: 1st July 2011, 07:30
  2. programming
    By vectra_ in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2010, 21:58
  3. Key programming
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2010, 22:18
  4. Key Re-Programming
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2008, 10:42
vectra cdti injector coding
programming vectra c injectors
do insignia injectors need coding
have injectors got to be coded on 1.9dth
tech2 programmer telford
how.much.is.it to.programm vectra injectors
1.9 cdti injector coding
tech 2 injector coding
does corsa 2007 cdti need injector coding
vectra c injectors
1.9dth injector
