Results 1 to 10 of 16
Thread: Vec 57 - Fan Speed 1-3 stopped working?
    Dec 2011
    sheffield
    Default Vec 57 - Fan Speed 1-3 stopped working?
    Driving back from work yesterday to find the fan wouldnt come on when selecting speed/setting 1, 2 or 3. The full speed (ie: fan setting 4) and the button to demist the front window works no problem? All other dash/electrical features seem fine too.
    Could it just be a fuse, if so which one do i need to replace.
    Thanks in advance
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    do a search for heater resitor or matrix
    http://www.google.co.uk/#hl=en&outpu...iw=708&bih=297
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    iirc there is a resistor or something that can blow, afaik its an easy fix, might be in the how2 section.
    failing that someone who knows will be along to advise
    Dec 2011
    sheffield
    thanks all,
    think ive found the issue thanks to this forum (again), looks like a common problem with veccys
    http://www.vectra-c.com/forum/showth...ll+scuttle+tay
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Resistor in the bottom of the blower motor housing. Accessible from the passenger footwell. £26 from the main dealers, and 20 minutes to fit yourself
    Full Member tolly's Avatar
    East Midlands
    Trim : SRI
    Engine : 2.2
    Year : 2002
    Quote Originally Posted by preecy View Post
    thanks all,
    hi m8. i had the same problem as you. i changed the resistor pack and still the same problem. but once i changed the heater control. all worked again.
    Regular Member pa51mon's Avatar
    Mar 2012
    lincolnshire
    i had this problem, changed the resistor and still didn't work. turned out to be relay. might be worth checking first as it is alot cheaper
    Full Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    I've just changed the circuit board in my heater control panel as this turned out to be the problem.
    Quote Originally Posted by tony-1977 View Post
    Or loads cheaper (approx £1) if you buy a new thermal fuse and replace it.
    http://www.vectra-c.com/forum/showth...=1#post1495923
    Sep 2009
    birmingham
    i had this same problem, got a new resistor off ebay £9.50, fitted it today (thanks to this site) got all speeds on my heater working now. part number 9180020
  1. Sub has stopped working
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2012, 16:35
  2. Sat Nav Stopped Working
    By alhambra in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2012, 19:24
  3. DAB stopped working
    By sandman1001 in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2011, 22:27
  4. Air Con stopped working
    By pvmoore in forum Troubleshooting
    Last Post: 30th July 2009, 22:31
  5. fan speed switch stopped working
    By beefycol in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2009, 18:06
