Thanks Thanks:  3
Likes Likes:  4
Thread: Passenger Foot Well
    Regular Member connor748's Avatar
    Jun 2012
    Atherstone
    Default Passenger Foot Well
    Lifted the mat tonight and noticed that the carpet is wet, waters getting in so where should i look first I'm guessing a drain plug is blocked but where is it?
    ta
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 137000
    Water leaking in car fix -* VIDEO *-
    click here
    http://www.youtube.com/watch?v=XxOxr...1&feature=plcp
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 137000
    check the drain by the drivers side as well by the wiper linkage
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 137000
    West
    if all the above is clear then check the plastic panel below the windscreen is clipped in securely
    Jun 2012
    Atherstone
    Cheers guys, all empty now its was full to the brim, just need to dry the carpet out now and now i know where the pollen filter is thats getting changed too.
    I love forums me, all the answers you will ever need only a question away.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 137000
    pollen filter is about 10 pounds inc vat
    code number 93172299 gm particle filt
    i used plenty on paper towels
    a vax to collect water
    and drove around with the heater on for a bit
    check the drain by the drivers side as well by the wiper linkage or it will come into the drivers side footwell aswell
    Apr 2012
    Ayrshire
    Vehicle : Vectra c
    Engine : 1.9CDTi (150)
    Nice one guys, will check mine on both sides and do the pollen filter as my windscreen is getting misty in this muggy weather.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 137000
    reminder to clean your scuttle tray out
    for new members on here
    Aug 2012
    South Wales
    Drag up an old thread
    really cant fault this forum had usual front footwell soaking but only happened after some little ****** decided to smash the front n/s window had auto glass out to fix so thought that was the problem sure enough the plastic membrane inside the door card all cut and torn so out with the polly tunnel repair tape and patched it up job done or so I thought till last night and it absolutely threw it down so done a quick search on here and sure enough the answer was there checked the scuttle drains and they were blocked and a fair bit of water in there needles to say pollen fillter foocked but hopefully this will sort it now
    keep up the good work everyone priceless forum
  11. Thanks dougie89, soulman, vectra ste thanked for this post
    Likes dougie89, puppet, richiefee, vectra ste liked this post
  1. Wet Passenger Side at Foot area
    By akeem in forum Bodywork & Interior
    Last Post: 9th November 2012, 10:29
  2. water in passenger foot well
    By crayon in forum Bodywork & Interior
    Last Post: 28th January 2011, 13:31
  3. water in passenger foot well
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2010, 16:39
  4. There’s water in the passenger foot well
    By Tadpole in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 22:36
