Thread: Injector Nozzles
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Default Injector Nozzles
    My engine is really lumpy on cold startups, kinda like it is choking a bit. Until I give it a few revs. Normally get a load of white/blueish smoke out of the exhaust too.
    After watching this video, which states it is a problem with injector nozzles, I realised my engine startup is pretty much the same
    http://www.youtube.com/watch?v=dseUEVVGsAw
    Skip to 1:15 for the startup.
    What you guys reckon? Possible nozzle problem? The car has done 86k miles. 1.9CDTi 150
    Could the fuel filter be the cause of this problem too?
    I have blanked my EGR off (don't know wether this is relevant).
    Thanks guys.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 133000
    from a thread i found
    Update so far......
    Well, I've cleaned the EGR out twice and cleaned the Boost Valve and cleared all the crud out of the airbox as well as the solenoid under the slam panel and I'm happy with the results.
    The engine starts easier now, is much less lumpy when stone cold and hardly smokes on start up. Result!!
    The only thing left is to clean the throttle body out, which I'll do either later on today or tomorrow afternoon if the rain holds off. The car is running much smoother now and its in for an oil service this morning
    Mar 2011
    Wirral
    I have also cleaned the throttle body, boost sensor (is this what he meant by boost valve?) aswell as airbox and changed filter. What is the solenoid under the slam panel?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 133000
    Quote Originally Posted by john506 View Post
    not sure you could pm signum 1.9 which this post came from
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 133000
    when was the last time you put glow plugs in?
    Mar 2011
    Wirral
    I haven't since I bought it, I bought it just over a year ago with about 79,000 on the clock.
    I was led to believe the glow plugs just give the initial heat to get the cylinders firing. The car does start up fine, just once it is stared, engine seems to shake a bit more than it should. Pretty much the same as in the video from the first post.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 133000
    Merseyside
    Check the Swirl linkage on top of the engine..... mine popped off earlier today and made it shoud like a bag of brown stuff when I started it up from cold. After an EGR and Boost clean and refitting the linkage it starts fine from cold - I've just checked
    Mar 2011
    Wirral
    Ok I will have a look, will it just be loose or completely come off if it is at fault?
  1. Replies: 6
    Last Post: 29th December 2012, 17:32
  2. washer nozzles
    By rick1965 in forum Vectra C / Signum Car Chat
    Last Post: 5th September 2009, 23:32
  3. Heated windscreen washers Nozzles faulty
    By lee_eardley in forum General Chat
    Last Post: 17th December 2007, 19:29
  4. Heated washer nozzles
    By Ste in forum Bodywork & Interior
    Last Post: 3rd April 2007, 14:18
  5. Heated windscreen washer nozzles?
    By stevedee3 in forum Electrical & ICE (including SatNav)
    Last Post: 26th June 2006, 03:00
