Results 1 to 10 of 17
Thread: suspected ecu problem
    Jun 2012
    widnes
    Default suspected ecu problem
    hi got a problem with my z18xe vectra c, car wont start well it wont even turn over, everything works on the dash apart from fuel guage and eml light doesnt come on, tryed putting it on a diagnostic machine and it wont connect says either error or igntion is off ect, all the relays click when u try to start it but it doesnt even turn over, i brigded the starter and the starter turns the engine over fine but obv doesnt start it, anyone else had anything like this? im sure the ecu has gone or there is no power getting to the ecu but iv traced all wires back and theres no split broken wires ect, any ideas would be great
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 141000
    are you still getting the padlock symbol ?
    Jun 2012
    widnes
    no mate padlock symbol is sorted now
    Regular Member vectrahunter's Avatar
    Feb 2007
    crosshouse
    My 1.9 cdti had the same fault as yours turned out in be corroded wires to the Ecu loom just where the loom passes over the front subframe
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 141000
    Quote Originally Posted by nath20vt View Post
    did you say you bought it as a non starter
    Jun 2012
    widnes
    im leaning towards either dodgy wires or the ecu ill check the ones you have mentioned tomorrow, yes was bought as i non runner
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Have you checked power an ground at ecu?
    Jun 2012
    widnes
    i havent no mate im absolutaly useless when it comes to wires and electrics, how would i go about checking them? iv checked the black earth on the ecu if thats what you ment?
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    iv checked the black earth on the ecu if thats what you ment?[/QUOTE]
    I thought the earth was brown
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Find good earth or if cable long enough connect to battery.
    Test power cable should see batt voltage.
    Swap round to post on Batt an test earth on ecu should be same.
    Earth to chassis are brown but ecu earths a usually black
  1. suspected alternator failure
    By redross555 in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2013, 00:36
  2. Suspected oil cooler issues 1.9 cdti 150
    By jay w in forum Engine & Drivetrain
    Last Post: 22nd October 2012, 22:25
  3. suspected cat failiure
    By interespray in forum Engine & Drivetrain
    Last Post: 7th January 2012, 16:40
  4. Suspected broken spring.
    By VectraMat in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2008, 09:00
