Results 1 to 10 of 24
Thread: No drain pluy on my gearbox???
    Regular Member Lozza's Avatar
    Jun 2011
    Brum
    Vehicle : Vectra c
    Trim : SRI
    Engine : 1.8
    Year : 06
    Default No drain pluy on my gearbox???
    Hi all... ive been reading through the forum and found out that there is no drain plug on the 1.8 zx18e gearbox (F17)
    So how am i supposed to change the oil and is it a hard job?
    thanks Loz
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    hi lozza
    your car has only done 40000 miles
    is there a problem with the gearbox
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    Jun 2011
    Brum
    Vehicle : Vectra c
    Trim : SRI
    Engine : 1.8
    Year : 06
    nah m8... just though id change the oil... looks like i ent gonna now tho lmao
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    ive only seen people on here change oil in the auto boxes only
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    have you found that noise yet
    and have you done the top mount bearings ?
    Jun 2011
    Brum
    Vehicle : Vectra c
    Trim : SRI
    Engine : 1.8
    Year : 06
    top mounts are done... no more knocking noise ... the rattling noise is the water pump i believe.
    I have a little oil leak on the crankshaft oil seal so im gonna do that and the WP at the same time
    just bought all the bits yesterday WP, CS seal, oil and coolant.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    Quote Originally Posted by Lozza View Post
    does the waterpump leak around the cambelt area
    dont use the same cambelt when changing have you got a new belt
    Jun 2011
    Brum
    Vehicle : Vectra c
    Trim : SRI
    Engine : 1.8
    Year : 06
    had the cambelt kit done at 38k.... so wouldnt that belt be ok?
    no water leak but sounds like the bearing is goin
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    To drain the oil you need to remove the gearbox sump and to refill, to refill you need to do it through the reversing lights switch
  1. :( So Fed Up - Gearbox spat out the drain plug!!!!
    Last Post: 12th July 2012, 09:28
  2. 2.2 TDi gearbox drain bolt ?
    By tosh23 in forum Engine & Drivetrain
    Last Post: 11th January 2012, 22:45
  3. auto gearbox drain plug
    By bert01909 in forum Engine & Drivetrain
    Last Post: 19th September 2011, 18:14
  4. gearbox drain plug
    By collyb in forum Engine & Drivetrain
    Last Post: 3rd May 2011, 13:47
  5. Gearbox oil drain plug
    By big nath in forum Engine & Drivetrain
    Last Post: 15th February 2011, 18:13
