Results 1 to 10 of 29
Thread: Swirl Valves......
    Merseyside
    Default Swirl Valves......
    Well after stripping just about everything else off and cleaning sensors and valves..... It ran perfectly again.
    Suddenly there was a loss of power at low revs again..... search under the bonnet to discover this......
    The rail has come off!!
    Is it easy to refit - if it comes off again is it new inlet manifold territory?? The car has a warranty for another 1500 miles or so.
    Whatever next????
    Jan 2012
    Lancs
    Vehicle : Signum Design 1.9cdti
    Now it's come off it will keep doing it, it can be popped back on pretty easy, but will do it again. I fixed mine with fibre washers glued in place, worked for a few thousand miles now. Like you said, when it's off you lose bottom end grunt, don't understand how these guys that glue the flaps open don't notice this ???????
    1st things 1st, try get it repaired under warranty, you might get a new manifold if you're lucky as they won't sell the bar as a single componant ( well they wouldn't when I tried )
    Merseyside
    How can I get in to refit the rail?? It appears I need fingers like ET!! some of the valves are in different positions too - how can I release and move them without damaging them??
    Jan 2012
    Lancs
    I used a thin strip of metal ( like a drain cleaner ) with a "V" bend in the end to get under it and lift it along with a long screw driver to help manouvre then push down the sockets. Use the screw driver to adjust all the swirls so they are in the 10 oclock position when engine is off ( basically exactly the same position as the 3rd from left swirl as this is the motor driven swirl ). But it will do it again unless you A) fix it B) new unit.
    Check all the swirls move freely 1,2,4 ( from left )
    Merseyside
    Quote Originally Posted by pthres View Post
    Cheers for the guidance - all seem to move freely - I had the same issue with my last engine in the old Signum. Just a pain its decided to come off now after all the other work I've done on it!
    Merseyside
    Rail re attached - just gonna give it a run. Thanks for the help..... had to butcher one of the metal Kekab skewers in the kitchen to make a long thin hook. Hope the mrs doesnt notice
    Jan 2012
    Lancs
    Quote Originally Posted by signum_1.9 View Post
    She'll be fine with that don't worry. :-)
    Looking at you pic it's quite worn, I'd try fixing it anyway whilst waiting to see what the warranty ppl say. Cost a tube of glue & a pack of washers. Lil bit of time and some sandpaper, 5mm drill bit, easy fix.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    when i had mine replaced because the bar fell off i didn't notice a difference. i wonder if anyone has completely removed the swirl flaps? i did it on my old mondeo mk3 1.8 petrol and was fine.
    Merseyside
    Well all I've done is re attach the rail and go for a drive..... Limp mode and no turbo boost!! What now?! There are no lights on or anything!
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    mmm looking at your previous post you've cleaned the egr and boost sensor. i wonder if the manifold is leaking pressure?
  1. Swirl valves on an '08
    By stevoxsi in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2012, 22:11
  2. re swirl valves
    By steve alan in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2012, 08:52
  3. Swirl valves
    By MattHD in forum Engine & Drivetrain
    Last Post: 18th April 2011, 12:45
  4. Swirl Valves
    By dhwigston in forum Engine & Drivetrain
    Last Post: 2nd March 2010, 15:13
  5. swirl valves
    By scoobyman in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2008, 21:14
can you free up swirl valve with wd40
