Thread: Vec c 1.9 150 towing advice needed
    mansfield
    Default Vec c 1.9 150 towing advice needed
    As title,
    i have gained my B+E licence (taken the test)
    the question is on the lead up to billing.........
    Im planning on driving the vec c with a Brian james trailer and the Calibra dtm on it, will i be legal?
    The calibra weighs 1265kg (although probably less with rust fall off lol)
    the trailer is plated iirc 1000kg per axle
    then there is the vec
    any websites with great answers etc also helpfull
    Steve
    Dec 2011
    Seaham
    Look at the Maximum towing weight of your vehicle, towing a braked trailer, it will be someting like 1200-1400kg. Compare this with the weight of the trailer + car on it. I think you will find that whilst it is not illegal to tow it, you will be restricted to something like 40mph due to the weight differences. The trailer should never normally exceed the weight of the car.
    However, I would NEVER recommend towing anything above the manufacturers towing weights. You will need a heavier tow car or maybe even a large van or a 4X4.
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    The maximum towing weight of a Vectra 1.9 CDTi 150 is 1600kg
    Aug 2010
    Derbyshire
    You will be way over you max permissable tow weight.
    As a guide the above post (Ben50n) is around what you could/should be towing but as a guide never tow more than the max kerb weight of your car.
    Mick
  1. Help advice needed
    By galway1 in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2012, 22:58
  2. Towing; Downgrade 3.0 to 1.9 Advice Please.
    By MRLUBBERLUBBER in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2011, 23:13
  3. Help or advice needed...
    By axelf in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2011, 00:15
  4. Advice needed please....
    By bobby-tupper in forum Detailing and Car Care Discussion
    Last Post: 23rd April 2009, 06:07
  5. Advice needed
    By tonyt in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2008, 19:58
