Thread: weichers strut brace....wont fit!
    Regular Member Jaspa's Avatar
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    Default weichers strut brace....wont fit!
    well after ordering my weichers strut brace 6weeks ago and it needing to be made to order it arrived today.....only to not flaming fit!
    the brackets fit the turrets fine, its all the right shape but when tightening it down the bar foulds the brake fluid resevoir as its too tall. any vec i seen fitted with this strut brace has a different style fluid resevoir and does not suffer from this problem
    i cant leave it as it is due to when full tightened their is serious risk of stress fracture as its only plastic, so kind of stumped.
    only solution i can think at the moment is make a 5mm (ish)base plate for the brace bracket to sit on which will lift it just enough to clear the fluid resevoi....any more ideas?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Mine only just clears it, I have to take if off to check the break fluid
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    i am aware that regardless its close but i theres just no chance at all its fitted unless a modify something
    Regular Member 4eyes's Avatar
    Birmingham
    This was commont to have to be done when I owned a Phase 2 Mk1 S40 where Volvo used to supply a bracket with the brace to move it up/down a few mm - it's only a bracket for the bolts that hold the reservoir and there were never any issues with those
    spoons
    Guest
    Just make sure if you raise the brace that you can still close your bonnet afterwards without distorting or bending it as the tollerences are next to zero...
    Regular Member Keif's Avatar
    In the Garage
    Jaspa, where did you order it from?
    Devon
    This is a well known issue with right hand drive Vectras and the Weichers strut brace. The solution is to buy slightly longer bolts and thick washers - this raises it just enough to clear the brake fluid reservoir. HTH
  1. Weichers Strut Brace Fitted
    By OPC in forum Handling & Braking
    Last Post: 17th March 2015, 13:59
  2. strut brace
    By sparky3865 in forum Handling & Braking
    Last Post: 8th May 2012, 13:35
  3. Strut brace for vec c
    By matty87 in forum Styling
    Last Post: 9th August 2011, 18:23
  4. Should i fit strut brace???
    By omega63 in forum Handling & Braking
    Last Post: 3rd September 2010, 23:03
  5. Weichers Strut Brace
    By parsco in forum Parts for sale
    Last Post: 7th July 2010, 13:47
