Results 1 to 10 of 21
Thread: One cleaned Boost Sensor......
    Merseyside
    Default One cleaned Boost Sensor......
    Well, I took the boost sensor out to check it. It looks fairly new from the outside so I wasn't expecting and horror stories inside...... How wrong was I!!! no wonder it was running rough still.....
    Before.......
    After.........
    Starts perfectly now - no rough running (its still warm). Hopefully after I've done the throttle body clean it'll completely cure the issue!
    Thanks to everyone for the pointers! Much appreciated!
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    and just think what your swirl flaps look like get you egr blanked asap
    Merseyside
    I cleaned the EGR out the other day and it wasnt as bad as I was expecting - the swirl valves seem to be operating ok - the bar is still firmly attached. The poor engine has just been neglected for a while. I'll look after it and have it running like silk in no time now
    Jul 2011
    UK
    Cleaned the one on the zafira t'other day, it looks exactly the same before and after!!
    Merseyside
    Mine was fizzing like mad when I sprayed on the carb cleaner. Came up almost as good as new as you can see!
    Merseyside
    Just popped out and done a cold start on the car - is a lot smoother than it was, but there is still the odd lump when its idling at cold temperatures. Could this be down to the throttle body being gunged up??
    West
    Engine off unplug egr, then fire up & give it a good thrapping down the motorway, you will feel the difference... i'm happy to run mine with egr unplugged & then just plug in at mot time tbh
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 129000
    plug it back in at mot you naughty man lol
    May 2006
    scotland
    Ditto.
    Aug 2012
    wirral, wallasey
    hi, do all 1.9 cdti engines have the swirl flaps, i have a facelift 2005 1.9 cdti sri 120, had a miss-fire at 2000 rpm, cleaned boost valve and egr, car runs much smoother and no miss-fire, however i can seem to find/locate the swirl flaps i here so much about??
  1. Cleaned boost sensor
    By 130786howe in forum General Chat
    Last Post: 8th July 2012, 16:22
  2. please help, eml still onl, cleaned boost sensor and egr
    By J P S in forum Engine & Drivetrain
    Last Post: 31st May 2012, 12:25
  3. Just cleaned my boost sensor
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2011, 19:43
  4. Just cleaned my egr and boost sensor !!
    By renton608 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2011, 17:32
  5. cleaned boost sensor and still shows over boost
    By chowwie in forum Engine & Drivetrain
    Last Post: 14th November 2008, 09:23
