Thread: Twin Exhaust Question.
    ijk571
    Guest
    Default Twin Exhaust Question.
    My vec, up until last week has perfectly even, level rear pipes.
    The local main dealer did a service and MOT on it. One of the advisory's on it was that the 'O/S rear exhaust was unhooked from support.'
    I'm guessing they have since hooked it back on (both rubber supports on both sides are now on) the exhaust is p****d.
    Strange this was, if it was indeed unhooked (I'm sure I'd have noticed) it was sitting perfectly level.
    This, lol, is doing my OCD for these things no good at all. All the brackets look straight and true and are supporting the exhaust. Could it be a simple case of buying 4 new exhaust mounting rubbers and seeing if that fixes it? Are they universal or Veccy specific? What else can I do to straighten them up?
    Not even sure which side is the correct height now
    Regular Member BBMadness's Avatar
    Apr 2012
    Merthyr Tydfil
    Check the rubbers, as one may be pushed further back or forward which causes it to pull up or drop down
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    left hand side looks slightly lower to me tbh but only by a small amount, go to a decent exhaust place and ask em to sort it for you, they should do it for a drink tbh
    hth
    ijk571
    Guest
    Thanks,
    Will try a local place when I can, otherwise I have found the rubber supports I need, wonder if I should just bite the bullet and give 'em a try...
    I've also tried to move the rubbers about and it makes no difference (confused now)
    Regular Member Ben Chiles's Avatar
    Feb 2011
    Redditch, West Midlands
    Sooo errr, where's the difference?!
    ijk571
    Guest
    Left one a bit low, not a great picture I know.
    ijk571
    Guest
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    Bend the left side hanging brackets up slightly with a pry bar. Or the right side ones down, depending on your preference...
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Quote Originally Posted by DeeBe View Post
    You'll probably find they had a problem hooking the rubbers back on and have just bent the hanging brackets on the bottom of the car down slightly in the process.
    ijk571
    Guest
    Got it sorted by replacing the two rubbers on the passenger side, looks much better now.
  1. twin exit exhaust question
    By rickeys16v in forum General Chat
    Last Post: 17th February 2013, 19:52
  2. 1.9CDTI Estate Twin Exhaust rear skirt question.
    By thefibreguy in forum Styling
    Last Post: 15th June 2010, 00:22
  3. Replies: 2
    Last Post: 8th July 2009, 11:09
  4. Twin Exit exhaust question
    By Governor in forum Styling
    Last Post: 7th July 2009, 18:17
  5. Twin Exhaust Question on Sri Estate
    By Dazfoz in forum Styling
    Last Post: 8th April 2009, 01:04
