Thread: tailgate light cluster not working on o/s
    Jun 2012
    manchester
    Vehicle : Vectra C estate
    Engine : 3.0 V6 CDTI
    Mileage : 126000
    Default tailgate light cluster not working on o/s
    I noticed that my o/s rear light cluster on the taiilgate of my estate vecy is not working.
    There is signs of some diy wiring from the regplate light going up over the roof lining.
    i did notice that the small plus that attach to the cluster only had 3 wires, whilst the correctly working one has 4 wires. see pics
    http://i48.tinypic.com/fyhbib.jpg
    not working
    http://i48.tinypic.com/zybwh1.jpg
    working cluster
    its the wire that should be marked "1" that is "missing"
    am I jumping to conclusions that this is the source of my problems?
    anyone know what this wire should be?
    thanks guys
    Lee
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    The extra wire should be on the O/S, it is for the rear fog light (in the UK, a fog light is only required on the O/S) the 3 wire one should be on the N/S.
    The first thing is to check the bulbs.
    Then the earth connections, on the bulbs and the connector, the brown wire is earth. Any loose brown wires in the area should probably be connected to earth/car body.
    Jun 2012
    manchester
    Mileage : 126000
    cheers for the reply. The bulbs are fine, i swapped them out on the other side, its like the whole cluster is dead. there is some diy wiring from the numberplate light and a large cluster of brown (earth) wirings that were taped up, ill take a look at these and make sure they are grounded properly.
    i think i have my o/s and n/s's the wrong way round also! the three wires are on the passenger side.
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    Well the only 'common' thing is the earth wire, so it's worth undoing the taped up wiring. Good luck getting it sorted.
    Regular Member unikarl's Avatar
    Nov 2011
    Grimsby
    I've just had rear light problems and thanks to a member on here I found out it was the rec unit in the boot. I got an eBay replacement and had it coded to the car and my lights now work as they should.
    Jun 2012
    manchester
    Mileage : 126000
    i have traced the diy wiring and its for a parking sensor that is not working, im guessing this was at some point wired into the reverse light. the plot thickes!
    Jun 2012
    manchester
    Mileage : 126000
    FIXED!!
    fyi
    there was a blackening on the light cluster where one connection of one bulb sat, bulb was fine but it was just a case of giving the metal a scrap to show some fresh surface for it to contact with. after that all works fine. thanks for the suggestions guys and for the replys
  1. No working rear lights or tailgate
    By TonyP2020 in forum Electrical & ICE (including SatNav)
    Last Post: 8th August 2016, 21:56
  2. My instrument panel cluster is not working
    By bale541 in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2011, 11:38
  3. tailgate lights not working
    By v6 sri diesel in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2011, 02:57
  4. Rear Light cluster
    By phildews in forum Styling
    Last Post: 25th July 2007, 03:32
