Results 1 to 10 of 17
Thread: Spongy brakes after pad change
    Jan 2012
    Merthyr Tydfil
    Default Spongy brakes after pad change
    Hi Guys,
    Changed my pads today and now the brakes are very spongy, if I pump the brake pedal a few times it stiffens up and then goes spongy again, im assuming I have an air lock? How do I rectify this please?
    Jazz.
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    New pads on old discs? Its pretty normal as the whole of the new pad is not in contact with the whole of the worn disc face. Give them a few miles to bed in and they will be fine. I assuming you didn't bleed them?
    Jan 2012
    Merthyr Tydfil
    i had to slacken the bleed nipple to push the piston back?
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Thats how you've got air in the system then - they need bleeding to purge the air out there's no need to undo the nipple to push the pistons back.
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Ah ok, yes possible you've got air in the system. Did you just open the nipple and close it when the piston was back?
    Jan 2012
    Merthyr Tydfil
    I opened the nipple, pushed the piston back and then retighten nipple
    Jan 2012
    Merthyr Tydfil
    Quote Originally Posted by alcutler View Post
    I tried to push it back without but it wouldnt budge so had to undo it?
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    I thought that when you push the pistons back all you had to do was take the cap off the Master cylinder reservoir
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Its no big problem - just needs bleeding - do you know how to do it
    Jan 2012
    Merthyr Tydfil
    Quote Originally Posted by Damo77 View Post
    Tried. Would not budge, loosened the bleed nipple and went back easy enough
  1. Spongy clutch
    By mspvxr in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2012, 12:03
  2. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  3. Replies: 14
    Last Post: 3rd September 2011, 20:23
  4. Vec B spongy brake issue
    By Caveman_nige in forum Suspension, Wheels & Brakes
    Last Post: 7th May 2011, 23:35
  5. Spongy brakes
    Last Post: 17th January 2009, 20:42
