Results 1 to 10 of 22
Thread: Arms or bushes?
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    Default Arms or bushes?
    As per the title really, I'm just after a bit of advice. My Vectra needs the rear upper arms doing badly. There is visible movement & an audiable clunk when I pull the top of the wheel towards me. What I would like other's opinions on is whether it is easier to to the whole upper arm, or just the outer bush. If the bush is most peoples choice, I would have to get a bush puller from somewhere!
    Opinions appreciated guys.
    South east
    Have you read my How 2? You don't need a bush puller, you make one from a length of threaded rod, some nuts, washers and a metal sleeve.
    Nov 2010
    East Midlands
    Trim : design
    Personally I would change the whole arms for what it takes - the outers can be replaced as said above - but the replacement bushes seem to be as expensive as the complete arm or not far off. Also if the outer bearing has worn I wouldn't think the inner one will be far behind it.
    Rebellions How2 is excellent and can be adapted to be used on other bushes around the car, where they need drawing out or pushing in.
    Quote Originally Posted by alcutler
    The outer bushes are £10 for a pair on eBay
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by marktaylor View Post
    Well spotted - the majority seem to be b/t 14 - 18 quid each - then there are the inner ones and the hassle of replacing the bushes - you can buy a pair of complete arms for less than £40 delivered - I can't comment on the quality but I replaced mine a couple of years ago with cheapos and there has been no problem since
    South east
    I'm on the 2nd set of outer bushes on mu UCA, the inners are 100% fine still.
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    One thing i would suggest is to whip the wheel off first and have a good look at what type of bush is in the outer part of the upper control arm.
    Unfortunately, I wasn't able to press mine out as the outer bush was a smaller size....... I ended up having to replace the whole arm The replacement bushes that you can buy on eBay are identical to the larger bush in the new UCA's from what I've seen.
    eBay bushes look like:-
    Good luck getting it sorted
    Damo
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    I saw the how2 but I didn't know if I'd be as well off changing the whole arm. How big is the sleeve you used? I've tried to measure up the bush & it looks approx 50mm long by about 50-55mm across. Does that sound about right?
    Dimensions for the tool you require
    South east
    Damo, I'm beginning to think the UCA you took off your car had been fitted the wrong way round - what you're referring to as the outer bush that is unusually small, looks like the inner bush. I can't find any reference, anywhere, of a Vectra UCA that has a different sized outer bush than normal.
  1. Upper Rear Control Arms replaced - bushes look shot on the old ones!!!
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 8th September 2012, 14:32
  2. Best place to get rear trailing arms/banana arms??
    By paz_badboy4life in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2012, 09:53
  3. banana arms
    By stickygreen in forum Suspension, Wheels & Brakes
    Last Post: 31st December 2011, 16:53
  4. Replies: 5
    Last Post: 21st March 2010, 12:34
  5. I'm ooking for rear suspension arms and ARB bushes?
    By monkeez in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2009, 11:42
