Thread: 1.9 CDTi wastegate chatter???? Induction kit....
    Regular Member Vectra Adz's Avatar
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Default 1.9 CDTi wastegate chatter???? Induction kit....
    Basically on my mk3 astra gsi turbo, it chatters when changing gear from the turbo, can this be done on my engine at all?? As eventually im gonna stick a straight through on it and get rid of the cat.
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    No one???
    May 2012
    chelmsford
    it should chatter abit with a cone filter. i put one on my mates tcdi mondeo 52 plate and that does it. dump the cat and let it breath better.
    Jun 2012
    Kent!
    Vehicle : SXi+
    Trim : GSi Spec
    Engine : 1910
    Mileage : 140k +
    Yeh im trying to get hold of a decat pipe for it at present, just wondering about MOT for it, as it already smokes bit at the moment when i load it up as its got a tuning box on it. lol
    Jul 2012
    scarborough
    It's not wastegate chatter its compressor surge. It happens when using lots of boost then let off the accelerator, the compressed air tries to go back over the turbo blades, this is why cars are fitted with dumpvalves, normally recirculating ones as standard as this dumps the excess air back into the system.
    You can make the noise more noticeable by using and induction kit getting the filter to turbo pipe as short as possible. The way of making it louder is by getting an after market recirc valve with a higher spring value which won't dump the air until more pressure is there.
    Regular Member amand's Avatar
    Feb 2011
    west London
    yep correct, compressor surge gives the owl hooting sound or the too too too tooh. when you give it full throttle and release before turbo kicks in.
  1. How to make my 1.9CDTi Wastegate Chatter
    By dannybl1990 in forum Diesel Engine related
    Last Post: 19th June 2012, 02:50
  2. 19.cdti chatter noise help anyone at all
    By 0114NIGEL0114 in forum Tuning
    Last Post: 25th August 2011, 10:15
  3. CDTI induction kit anyone got one?
    By ONEMINUTESILENCE in forum Diesel Engine related
    Last Post: 2nd August 2011, 21:10
  4. Can you change a cdti to external wastegate?
    By swifty_53 in forum Diesel Engine related
    Last Post: 1st March 2011, 01:10
  5. 3.0 cdti Induction Kit?
    By redleader in forum Diesel Engine related
    Last Post: 14th January 2010, 00:44
astra 1.9 cdti external waste gate
vauxhall astra 1.9 cdti external wastegate
astra 1.9 cdti sri induction kit
how to free the wastegate on vectra 1.9 cdti
cdti owl noise
adjusting cdti waste gate
vectra c dti adjust wastegate
