Results 1 to 10 of 26
Thread: Changing front pads?
    Jan 2012
    Merthyr Tydfil
    Default Changing front pads?
    Hi,
    Im going to change the front pads on my Vec, reading the how to it seems straight forward. Question I have is in the past ive always been told to take the cap of the brake res but the how to doesnt mention this? does it need to be done or not?
    Jazz.
    Quote Originally Posted by Welsh_J_2000 View Post
    Yes
    Not sure why it would not be mentioned
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    There will be people who say yes or no. I changed mine without releasing the cap and it wasn't a problem. It is meant to make it easier though.
    Jul 2011
    UK
    Year : 06
    Makes it easier when pushing back the piston
    Jan 2012
    Merthyr Tydfil
    Quote Originally Posted by marc vectra sri View Post
    With the cap on or off Marc?
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    I've never taken the cap off the reservoir when changing brakes and I've probably changed 5000+ sets
    Nov 2010
    East Midlands
    Trim : design
    You need to take the cap off -to release the pressure created when you force the pistons back to make room for the new thicker pads - watch out for brake fluid overflowing from the master cylinder reservoir as well - best wrapping a piece of rag around the neck of the reservoir to catch it
    Dec 2011
    Seaham
    There must be a very small bleed hole in the caps, otherwise you would end up creating a vaccum in the resevoir when the pads were worn and the calipers need more fluid behind the pistons??
    Personally I would leave the cap on.
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    All the caps "breathe" thus the reason you change your brake fluid as moisture from the air gets into the brake fluid
    Jul 2011
    UK
    Year : 06
    Yer but others have said there no real point my mate had a rattle from his tool his wheel off pushed the caliper right back removed the caliper found the fault and put everything back and pumped the pedal
  1. Changing front pads??
    By degsy1234 in forum Handling & Braking
    Last Post: 14th February 2012, 16:56
  2. Changing brake pads
    By Sean-2.2Direct in forum Suspension, Wheels & Brakes
    Last Post: 26th November 2008, 17:58
  3. Changing Pads
    By lesbo in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2008, 09:43
