Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Steering Wheel with Exclamation Mark and more....... PLEASE HELP
    Regular Member Chris R's Avatar
    Jan 2008
    Leamington Spa
    Exclamation Steering Wheel with Exclamation Mark and more....... PLEASE HELP
    Just had a daunting trip to Sainsburys in Leamington Spa, went to get some shopping (as you do) and came back to the car. Car would not turn over!! All ignition lights came on as normal, except for the fuel gauge not starting up, and the steering wheel with the exclamation mark and abs light flickering on and off (as shown in the picture attached), but then power got cut when i turned the key further to start the engine. I called the RAC out and the guy was amazing, done a dianostics check and came with NINE (9) fault codes. And here goes
    U0009, P0480, P0481, P1613, U0121, U0140, P0501, P0564, P2638.
    Can anyone help me with this pleeeeease
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    it sounds like the cim thats causing the problem
    Jan 2008
    Leamington Spa
    whats the cim?
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    lol i don't know i was looking up your fault codes all i know is the cim is important for the vehicle to work
    RO - all of South UK jaqubek's Avatar
    Sep 2011
    london
    16 Post(s)
    2 Thread(s)
    Vehicle : Vectra C Estate
    Engine : v6 3.0cdti
    Column Integrated Module
    Basically its the hub which all the low,mid and high speed canbus networks go to,along with your immobiliser and ecus.its right on the steering column.car wont work without it.
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    CIM, Collum Interface Module. Was thinking the same Dan, its the module behind the steering wheel. Lots of stuff goes through it, immobiliser being one of them. Either that or the ECU is goosed. Sorry only a guess.
    Regular Member mat_splat's Avatar
    May 2012
    Frimley
    Control interface Modual. That consists of the ignition barrel, immobiliser, wiper/indicator stalks, airbag and steering wheel wiring and the steering column position sensor. They have an ident on them, 2 letters. If you get the casing off around the steering column you can check which version it is.
    Jan 2008
    Leamington Spa
    haha fair enough lol the RAC guy was sayin somethin about a CANBUS??? ill put a picture of the report he wrote for me anyways... really want to avoid takin it to the stealers without finging out the problem first!!
    Jan 2008
    Leamington Spa
    P2638 worries me the most, Replace ECU
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    U0009 CAN bus communication nodes no C-005
    P2638 control device to replace C-002
    P0480 cooler fan (small) short-circuit/interruption
    U0140 CAN bus no communication with CIM (Steering Column module) C-003
    U0121 CAN bus no communication with ABS / TC C-003
    P1613 immobiliser signal error
    P0481 cooler fan (big) short-circuit/interruption
    P0501 vehicle speed signal is not in setpoint range B-023
    P0564 Cruise Control Multi-Function Input Signal????
  1. facelift vec, yellow steering wheel light with exclamation mark on startup
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2013, 16:55
  2. steeringwheel with exclamation mark
    By nadeem69 in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2012, 21:00
  3. Steering warning light with exclamation mark
    By bhod73 in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2012, 10:23
  4. Steering Wheel/Exclamation Mark
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 1st May 2011, 21:36
  5. Replies: 7
    Last Post: 22nd December 2006, 23:23
vectra c steering wheel with exclamation mark
vectra c steeringwheel exclamationmark
