Results 1 to 10 of 11
Thread: Where Should I Fit My Amp?
    Regular Member Bethan39's Avatar
    South Wales
    Default Where Should I Fit My Amp?
    I need some advice if possible i have one of these
    http://www.alpine.uk.com/p/Products/...rs2787/mrx-f30
    I need it to be out of sight so i was thinking of putting it under one of the front seats it's not that big 250 x 58 x 230 mm but it would then be next to the floor heating vents (could they be blocked off?) is there any other reasons not to put it under the seats? or maybe in the boot i've removed the right hand side panel and behind the cubby hole flap is enough room to fit it there just means lots more cable to run so you would open the flap and just see the Amp and the light. What do the Ice Gurus think. Thanks
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    if under the seats its possible someone's foot could do damage.
    cubby hole in the boot would get my vote
    Regular Member roverjay's Avatar
    Feb 2012
    Skelmersdale
    Vehicle : Vecta
    Trim : sri
    Engine : 1.8
    Mileage : 39000
    Screw it to the back of the rear seat
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Quote Originally Posted by roverjay View Post
    +1 as that's where my 2 amps are sitting
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    Cubby hole in the boot if you want to go totally stealth, that's what I would go for.
    South Wales
    Quote Originally Posted by J P S View Post
    Good point about someone's foot, back seats no good needs to be out of sight (and out of the way) looks like the boot suggestion is looking more favourable
    Jul 2011
    UK
    Year : 06
    Under the boot carpet in spare wheel used to put my amps there even used to have one under the rear seat bench
    Regular Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    The easy option is attach it to the back of the rear seats, or like the others said want it to look neat then store it in the cubby hole in the boot.
    Sep 2011
    Birmingham
    Trim : sri
    i have fitted a few amps in my time and in different cars.
    the back of the seats is a useful option but it does limit things if you ever fold the seats down.
    going in the cubbyhole thing means it should never be in the way, just my thoughts.
    well unless you want that cubby hole then the amp would be in the way lol
    Sep 2011
    Birmingham
    Trim : sri
    just make sure it can get enough air for cooling of course, especially if it will be driven hard
