Thread: Z30DT EGR Removal - How do I do this?
    Apr 2011
    Northamptonshire
    Default Z30DT EGR Removal - How do I do this?
    Does anyone have a guide to removing the EGR on a Z30DT?
    Ian
    Why do you need to remove it?
    Surely it hasn't failed already?
    If so, is your car covered by a warranty?
    If you are considering blanking, then it is bad news as you can't on this engine without having to make other modifications (including turbo and EMS)
    Apr 2011
    Northamptonshire
    I am experiencing judder/hesitation almost every time I try to accelerate then spanner symbol and car is in limp mode. I have a P0093-52 code pointing to the EGR, I'd like to take it off and try cleaning it again, problem is the bottom 2 screws aren't easily accessible so suspect there is an easier way to get at it.
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    If its sane as y30 the upper inlet manifold has to come off
    Quote Originally Posted by iani View Post
    The spanner is Engine Warning light
    Normally the EGR puts the Emissions Warning light on instead
    Yes, access to the screws on the EGR Valve is very poor
    Sadly you CANNOT clean the EGR Valve on any of the V6 CDTI engines on the Vectra C (Y30DT and Z30DT), so have the code read correctly by TECH2 to make sure this diagnosis is correct
    A new EGR Valve is not cheap, although it does the resolved the issue for the next 90K miles (3 services)
    Apr 2011
    Northamptonshire
    I got hold of a S/H EGR off eBay yesterday and fitted it this evening, not too bad a job and would have been <1hr if I'd thought to put the lower gasket in place before bolting the EGR on. Took the car for a drive and for first few hundred yards was great, then spanner light & limping, drove home. I reset the DTC (P0093-52) and decided to check if the fuel filter had indeed been replaced at last service as I had a spare one, filter was clean so put lid on. Thought I'd take car out again to check fuel supply ok after disturbing filter and car was perfect, took it for 10 mile blast and it performed better than it had in a long time. I'm doing 60 mile trip tomorrow so hopefully that should go ok. Replacing the EGR on Z30DT isn't difficult at all, I'm sure I could halve the time next time round (maybe not too far away as I fitted a S/H part)
    Ian
    How much did you
    Pay for the s/h one off ebay
    Apr 2011
    Northamptonshire
    Quote Originally Posted by marktaylor View Post
    How much did you
    £60, it was very clean and came off a car with 40k miles. I've just done another 30 miles this morning and car running great.
    I agree, second hand EGR Valves on eBay UK can be purchased for less than £100
    Compare that to the £400 a dealership wants
    Looks like I may as well buy the vectra-c.com membership to obtain my Trade Card...
    the z30dt egr valve is only £112.50 +vat with trade club , its the y30dt thats the expensive one
  1. Z30DT Question
    By rmg1 in forum Vectra C / Signum Car Chat
    Last Post: 16th August 2012, 20:42
  2. Z30DT stops
    By Johnny-B in forum Y & Z30DT Specific
    Last Post: 9th August 2012, 15:14
  3. z30dt egr valve
    Last Post: 9th May 2012, 19:10
  4. Z30DT DPF Re-Gen
    By ben_3.0v6 in forum Y & Z30DT Specific
    Last Post: 3rd January 2012, 21:37
