Results 1 to 10 of 13
Thread: Should I get the EGR and DPF removed and mapped out?
    Regular Member messermitch's Avatar
    Aug 2009
    Yorkshire
    Engine : 1.9Cdti 150
    Default Should I get the EGR and DPF removed and mapped out?
    Hi, My 1.9CDTI 150 is going into MAS performance for a remap in the next couple of weeks. Do you guys think I should get the EGR + DPF removed and wrote out of the software? I know they both cause many problems so its kinda making sure they wont go in the future but is there any disadvantages of having them removed?
    Any comments greatly welcomed
    Aug 2009
    Yorkshire
    All them views but no opinions????
    Jul 2011
    UK
    Year : 06
    Get the egr removed blanked out saves ya manifold also do u have a auto or estate if not u won't have a dpf
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    the only thing i would be careful of is there are rumours that they ma change the MOT so if youre meant to have a dpf and dont it could fail.
    i have just had mine cleaned and i am still very tempted to get it remapped and deleted but havent decided yet
    West
    If you're keeping the car for a good length of time then have the dpf & egr mapped out, saves on heart ache later
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    I would defo do it, it will save problems in the future when they inevitably go wrong.
    Jan 2012
    Lancs
    Vehicle : Signum Design 1.9cdti
    Ben ( MAS ) did mine a while back, taking the dpf off physically also gave me another 15bhp ( rolling road before & after ). Egr now blanked & oil catch can fitted so no more crap going into inlet. However as already said the rules have changed a little with dpf so if I were to do it again, I would leave the DPF in place physically but have a stright through pipe fitted through the middle of it to give the impression it's still a working unit :-)
    Regular Member Marky's Avatar
    Jun 2006
    North West
    First of all it looks like you have a Signum? Unless it's an auto you won't have a DPF.
    The DPF, even when working 100%, does reduce the power that the cars engine can produce but the biggest reason to remove the DPF is usually because it keeps getting blocked. If the car does not regularly get driven on the motorway or on a fast A road for around 30mins then the DPF doesn't get cleared out properly and starts to cause issues. If this is the case I would be tempted to do something about the DPF.
    As mentioned above it's a little unclear as to whether your car will fail an MOT if you remove the DPF. One MOT test place I have been to has said they would fail the car another has said they wouldn't so who knows!?!?
    Maybe another option is to get the DPF regen cycle tuned. I don't know if MAS can do this but on the EDS remaps with the DPF they have tuned the DPF software so that it regens more often and under different conditions. So its far less likely to get blocked.
    Jan 2012
    Lancs
    Quote Originally Posted by Marky View Post
    Mine's a manual, it had a DPF.
    Why not put a straight through pipe right down the middle of the DPF to give the illusion of a fully working unit?
    Jun 2006
    North West
    Quote Originally Posted by pthres View Post
    Really! You learn something every day. Ignore my comment about the auto then
  1. anyone mapped a 120 cdti??
    By bubba in forum Northern Ireland (RO - Vacant)
    Last Post: 20th January 2012, 01:15
  2. Anyone mapped their own Vectra? Is it possible?
    By Coupe2T in forum Diesel Engine related
    Last Post: 11th September 2011, 17:02
  3. Do you have to blank the EGR off if it is mapped out?
    By mattyc in forum Diesel Engine related
    Last Post: 11th August 2011, 15:24
  4. Can a 130 diesel be mapped same as a 160?
    By SteveBray in forum Insignia car chat
    Last Post: 11th January 2011, 11:37
  5. Well, i'm now EDS mapped!! WOW!
    By MCD in forum Diesel Engine related
    Last Post: 14th August 2009, 17:46
