Thread: P0638
    Aug 2010
    york
    Default P0638
    car is a 54 reg 2.2 DTI,,error code P0638-5B ( throttle control positive deviation )
    This is the sensor on side of throttle body to which i believe controls the butter fly in side. I have cleaned inside of throttle body,EGR and boost sensor ( thought build up of gunge might be causing problem).unfortunately error code still their.....
    is it just a case of changing this sensor meaning its just an electrical fault or is it the inners on the throttle body to where sensor connects.
    any HELP appreciated......
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Is it not a throttle pedal fault?
    Aug 2010
    york
    not 100 % sure,but think its the sensor on side of throttle body itself,the one inline with the oil cap ( although not all DTI engines has the sensor there.)
    Aug 2010
    york
    anyone else had this error code , and what they did to cure this problem.
  1. P0638 and EGR problems
    By ldanieli in forum Engine & Drivetrain
    Last Post: 28th May 2012, 10:56
  2. Fault Code P0638
    By Micknal in forum Engine & Drivetrain
    Last Post: 10th November 2011, 15:22
  3. Fault code P0638
    Last Post: 9th November 2011, 17:43
  4. Fault code P0638
    Last Post: 9th November 2011, 17:41
opel signum 2.2 dti p0638 hiba
p0638 fault code vauxhall positive deviation
p0638 vauxhall
