Results 1 to 2 of 2
Thread: heated seat fault
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    Default heated seat fault
    the heated drivers seat in my elite is not working , just after any info anybody may have , the switch lights up & I have identified a live feed to the seat when the switch is on , this live feed is in a plug of 5 wires .
    what I am wondering is if there is supposed to be a feed back to the switch in order to control the thermostat , I have no wiring diagram at present but could really do with a bit of info .
    May 2012
    county durham
    Mileage : 145k
    worked it out for myself in the end as even autodata had no wiring diagram , took the seat out & stripped it , using a battery charger , test light & multimeter I found out the bottom heater pad was open circuit , did a bit of tracing on the heater pad & narrowed the fault down to a 2 inch section of wiring , soldered a bypass wire across it , rebuilt the seat & hey presto it works a treat
  1. Heated Seat
    By gary_e in forum Bodywork & Interior
    Last Post: 28th August 2012, 20:52
  2. Replies: 42
    Last Post: 1st April 2012, 16:03
  3. heated seat switches? also electric seat adjust questions?
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 11:48
  4. Heated seat help!
    By lukesignum in forum Bodywork & Interior
    Last Post: 22nd January 2010, 18:13
  5. heated seat
    By craig1883@hotmail.co in forum Electrical & ICE (including SatNav)
    Last Post: 15th February 2008, 18:15
car heated seat fault
vectra c heated seat problem
