Results 1 to 10 of 18
Thread: z18xe Idle issue on cold start up
    Newbury
    confused z18xe Idle issue on cold start up
    Hi, I've searched the forum (maybe not well enough if there is something in the depths of the threads). I can't find something that refers to the 1.8 petrol engine that when it is cold the auto choke 'searches', and each time the revs drop evry few sconds the engine has a bit of a burble/misfire/lumpy. So to confirm;
    1. Turn engine on
    2. Auto choke works and revs increase to over 1500rpm for a second
    3. Revs drop for a second or two and engine misfires
    4. Revs increase back up to over 1500rpm for a second
    Step 3. again
    Step 4. again
    Step 3. again
    Step 4. again
    Then after 30 seonds or so the idle drops to below 1000rpm and there is no misfire. The car drives well and there is no issue when the engine is warm/hot.
    I've replaced the oil, oil filter, spark plugs and I use Redex. There is an engine light on the bottom right of the dashm which mechanic says is possibly a fuel/injectors thing hence advising me to use Redex.
    Any ideas folks?
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    What is the car mileage??
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    I would start with giving the throttlebody a good clean out with carb cleaner, blow through all the attached hoses and make the butterfly valve is free from crap and moving without issues..
    Newbury
    milage is 68k 2002.
    Newbury
    yeah i've seen the threads that refer to that suggestion. I have no idea where the throttle body is or how to safely remove it, I did see your or someone picks with a before and after of something with a gold looking flap in the middle of a barrell. I can pick up some carb cleaner from a motor store, but sadly one is a complete novice with an engine.
    Newbury
    I've got a fuel filter to replace, but I have no idea where the filter is on the car....I think I'll be looking for a Haynes manual very soon!
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 127000
    have a read of post 5
    http://www.vectra-c.com/forum/showth...uttery-missing
    does it sound the same?
    Jun 2009
    South Coast
    you will not need to actually remove the TB from the engine to clean it, depends on how bad it is. Follow the airbox induction pipe to the engine, where it connects to is the throttlebody (TB). undo the clip holding the pipe on and move it to the side, the get some clean cloths and carb cleaner and go to town on it, i also used an old toothbrush.. the samller pipes coming off the side of it can be removed and blown through, use a safety pin of similiar to push the the breather holes in the TB where these smaller pipes were connected.. is quite an easy job tbh, don't worry about getting carb clean into the TB as it evaporates, just give it a real good go over..
    Fuel filter is under the car, roughly under the rear drivers side passenger seat, use googles or keep rags handy. Best not to do this if you run the engine in the last hour as the system will still be pressurized. use two small flat blade screwdrivers to release the retaining clips..
    let us know how you get one..
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I think you need the codes read first and then it might point you towards the item that is faulty, possibly the MAF which is common along with the the thermostat not working
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    More info on here than in Haynes.
  1. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  2. Cold start issue - Thread 1,426
    By Barlow in forum Troubleshooting
    Last Post: 30th August 2012, 18:29
  3. fast idle speed on cold start (1.9cdti)
    By marky2027 in forum Engine & Drivetrain
    Last Post: 2nd February 2012, 15:00
  4. vetra 1.9 cdti cold start issue
    By all vaux in forum Engine & Drivetrain
    Last Post: 21st December 2011, 20:33
  5. vectra c 2003 2.2 dti cold start issue
    By sjs in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2010, 14:59
vectra c idle problem from cold
z18xe cold starts
z18xe cold start problem
