Results 1 to 10 of 17
Thread: Swirl Valve on a 150 Diesel......
    Merseyside
    Default Swirl Valve on a 150 Diesel......
    Right, I've cleaned the EGR twice, its now working properly and cleaned the filter on the little solenoid under the slam panel.
    The hesitation is still there at say 1200 - 1700 rpm. There are no fault codes showing and can't think of any other things that the problem might be.
    It was also pretty lumpy when starting up from cold.
    Its a 2006 55 plate with 81k on the clock - I have a suspicion its the swirl valves - would that cause these symptoms? The car has a warranty for another 2 1/2 months or 1500 miles so this would be covered - is it likely to be this old issue rearing its head?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Could be the injector loom for the 3rd injector. If yellow you will have the old ones, if it's the updated ones then they will be blue.
    Are the vacuum hoses ok? They are the little black hoses which come off of the vacuum pump in and into the solenoid (the filter you just cleaned). These are prone to perishing.
    Aug 2010
    Derbyshire
    As said above all could be checked and also boost sensor. Although dirty sensor will cause lack of power low down, no harm in cleaning if you already haven't done it.
    Mick
    Merseyside
    Quote Originally Posted by GazCDTI150 View Post
    I've checked all the hoses - they all appear fine and intact. Where can I find the injector loom??
    Quote Originally Posted by MickAP View Post
    Mick
    Where can I locate the boost sensor??
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    The loom it as actually the plug, it's about £12+VAT from the dealer. My local dealer supplied and fitted the 3rd injector for £50, however if you get all 4 done it would be about £120.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    Merseyside
    I'll have a go at the boost sensor tomorrow after the car has had its oil change service - looks like it could be part of the issue - the hesitation is far less noticeable now. Thanks everyone for the help. I'm just remembering my way around this engine
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Mileage : 142000
    this thread has good info hope this helps
    http://www.vectra-c.com/forum/showth...ight=tony+1977
    im glad you liked my posts
    Merseyside
    Quote Originally Posted by vectra ste View Post
    I note that a mention has been made of spraying carb cleaner in through the throttle body to remove any build up of deposits - I can't seem to find a pic of the location of this - any help??
  1. Diesel around the swirl valve seats.
    By felixx in forum Engine & Drivetrain
    Last Post: 27th January 2011, 18:10
  2. Egr valve, swirl valve problems etc..
  3. Swirl Valve
    By Doug-SRidirect in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2009, 14:05
  4. swirl valve do you need to use them
    By chrisgettings in forum Engine & Drivetrain
    Last Post: 29th March 2009, 22:59
  5. Swirl Valve Q??
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2008, 11:30
