Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: 1.8 petrol in limp mode!
    Jun 2012
    wolves
    Default 1.8 petrol in limp mode!
    hi all i have just changed my steering rack and went for a test drive all was well then all of a sudden my car cut out and now is in limp mode any idea please
    Jun 2012
    wolves
    also im guessing its in limp mode because it wont rev atall and stays at 1500 and misfiring
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Do the good old pedal test and see what fault codes come up.
    http://www.vectra-c.com/forum/showth...-any-Equipment
    Jun 2012
    wolves
    hi what do you mean by pedal test
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    As per the link. If its gone into limp home mode there will be stored codes.
    The porcedure is simple and is done from the drivers seat, with NO equipment.
    Get in
    Press and hold both brake and accelerator pedals to the limit of their respective travels
    Turn ignition key to Position 2, ie dash lights on
    Release accelerator pedal
    Re-depress accelerator pedal to the floor
    Turn off ignition
    Turn on ignition to position 2
    The engine symbol on the dash will then begin to blink
    There will be a sequence of flashes, separated by small pauses between numbers and a longer pause between separate fault codes.
    The number of flashes needs to be counted and thus the 4 digit fault code can be determined.
    EG, if the flash count goes as such
    10 flashes
    small pause
    1 flash
    small pause
    1 flash
    small pause
    10 flashes
    Longer pause
    10 flashes
    small pause
    1 flash
    small pause
    10 flashes
    small pause
    10 flashes
    Then there are 2 fault codes recorded and they are
    0110 (ie 10,1,1,10 flash sequence)
    and
    0100 (ie 10,1,10,10 flash sequence)
    Hope this helps
    Jun 2012
    wolves
    ah sorry link didnt show up first thanks will have a look now and will reply
    Jun 2012
    wolves
    i have 8 fault codes?????
    Jun 2012
    wolves
    this is how it was shown 1481, 0131, 1500, 1550, 1525, 1523, 0110, 0100
    Jun 2012
    wolves
    two of the codes point to air flow sensor is there another way to check it is the air flow sensor ive tried unpluging it and its no diffrent
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    If youve unplugged it and there is no change, it may be that that is causing the issue. Disconnect the battery for half an hour(as long as you have the car pass for your stereo code), and that should clear all the codes, when you reconnect start the car and see if it is still in limp home mode, then do the pedal test again to get you whats wrong with it.
  1. Limp mode!!! HELP
    By J's Turbo in forum Engine & Drivetrain
    Last Post: 14th October 2011, 15:06
  2. car going into limp mode 1.9 150
    By bingo999 in forum Engine & Drivetrain
    Last Post: 4th October 2011, 19:30
  3. 2.2 Dti limp mode
    By j88nya in forum Engine & Drivetrain
    Last Post: 2nd October 2010, 21:24
  4. Help please!! Limp mode...
    By scrumpus in forum Engine & Drivetrain
    Last Post: 17th April 2010, 07:21
  5. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
