Thread: 1.9cdti 120, low power 'to do list' Help needed
    Regular Member Sierra2's Avatar
    Sep 2010
    London
    Trim : SRI
    Engine : 1.9cdti (120)
    Mileage : 45k
    Default 1.9cdti 120, low power 'to do list' Help needed
    Afternoon all.
    Following on from my posts on smoking since the Turbo shat it's self, I'm now down on power and still suffering cold start idle issues.
    The Slick 50 engine fuel treatment seems to have worked on reducing the smoke output when the Turbo starts spooling.
    The 'How 2 section' doesn't really list anything on the 120. Can anyone help me out with a shopping list of things to do, ie: Clean/replace air filter, replace leak off pipes, clean EGR (does the 120 have an EGR?) clean throttle body, etc etc...
    If anyone who is knowledgeable of and works on there own 120 engine, is free help out with doing any of the above, I can return the favor if you need any wiring/installs done (hands free, satnav, audio, reverse parking cam/sensors, interior lighting, HID's etc etc. I'm based in West London.
    Can the 'How 2 section' be updated to include what can and cannot be done on a 120 engine?.
    Thanks in advance
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    The how2's for the 150 are all pretty much the same for the 120 engine.
    Yes the 120 does have an EGR...
    There's numerous posts with regards to poor staring. Most point to the usual. Starter Motor, Glow Plugs, Battery etc...
    PRESTON
    Things to check/clean on 120. EGR valve, boost sensor, vaccum pipes to the boost control valve. Starters are becoming a common starting issue on 120, it appears that they eventually slow up with age, not turning the engine over fast enough for compression ignition to take place. Start with the above and go from there, likely suspect is the egr if high miler.
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Might also be worth checking/cleaning intercooler pipework also check that the intercooler hasn't been damaged (small holes) easy to check with soapy water (look for bubbles when engine is running).
    Have a look to see if the throttle body butterfly is clean and not gunged up
    Only other thing I can think of regarding smoking is that perhaps the pre-cat and main cat may still have oil reside thus causing the smoke.
    Good luck
    Damo
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by Sierra2 View Post
    Afternoon all.
    Thanks in advance
    Before you spend any money get the car scanned with a Tech 2 or Vaux-Com diagnostic software.
  1. fuse list needed to check windscreen washers
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2010, 13:06
  2. List of what need doin for each service????1.9cdti 150
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2009, 16:30
  3. help needed LOSS OF POWER 1.9CDTI
    By vectra666 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2009, 20:06
  4. 1.9cdti 150 low power???
    By shewy in forum Engine & Drivetrain
    Last Post: 25th April 2007, 23:14
