Results 1 to 10 of 13
Thread: Inner tire wear on rear
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Default Inner tire wear on rear
    I nipped into Mr Tyre yesterday to get a slow puncture repaired and when the guy took off the wheel we could see that the inner side of the tyre was worn badly. The wear was probably about 2" wide right on the edge. But the wear did not seem to be even, it was worse every 4 inches or so all the way round the tyre, but the worn spots were very evenly spaced and totaly symetrical if you know what i mean.
    The guy thought it was the upper bush? He wiggled the wheel but i could not see any movement at all.
    We checked the other side and it was identical.
    Will try to post a pic later once i get a chance.
    South east
    It's very common. Sometimes it's the outer bush in the upper control arm that causes it, sometimes it's the rear camber being wrong. Your tyres might start making a droning noise soon, just like a failed wheel bearing.
    Engine : 1.9 CDTi
    When he wiggled it was the weight of the car on the wheels?
    If not with the car parked pull the top of the tyre towards you as hard as you can and see if there is any play.
    Jun 2011
    wolverhampton
    Were the Tyres brand names? As budgets do tend to wear unevenly
    Nov 2011
    Akrotiri, Cyprus
    The tyres are pirellis so not cheap ones. And the car was jacked up when he wiggled it. I think i may see if i can get the tracking / camber checked out somewhere.
    East Midlands
    ?Has the car been lowered at all.
    Nov 2011
    Akrotiri, Cyprus
    Yes it has, eibach pro springs and bilstein b6 shocks. Think about a 30-40mm drop over standard
    East Midlands - Regional Organiser new boy's Avatar
    Nov 2010
    lincs
    48 Post(s)
    Vehicle : BTCC Edtion
    Trim : SRI LEATHER
    Engine : 2.0 TURBO
    Year : 07
    Did you get it tracked and camber set after it was lowered?
    Nov 2011
    Akrotiri, Cyprus
    The car was already lowered when i bought it so not sure if the previous owner had it set up right so that may be a good point lol!
    Engine : 1.9 CDTi
    Have you done the check I posted as getting the camber and tracking checked with worn bushes is a waste of money.
  1. Rear tyre wear
    By Geoff644NI in forum Suspension, Wheels & Brakes
    Last Post: 29th March 2011, 22:00
  2. Rear brake pad wear
    By Corey in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2010, 10:25
  3. Uneven rear brake wear
    By Wingnut in forum Suspension, Wheels & Brakes
    Last Post: 1st February 2009, 20:51
  4. Rear Tyre Wear
    By johnmac in forum Suspension, Wheels & Brakes
    Last Post: 28th June 2008, 22:20
  5. Rear tyre wear
    By nhoj in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2008, 15:10
