Results 1 to 3 of 3
Thread: Dexron III for my AF40 automatic gearbox?
    Apr 2012
    London
    Default Dexron III for my AF40 automatic gearbox?
    I went into euro car parts today to go and get some fluid for my AF40 autobox to start the process of flushing the transmission due to a shifting problem.
    They recommended to use Dexron III? I just thought id check with you guys if this is the correct fluid to use as I dont want to use the wrong fluid and ruin what is quite an expensive transmission!!
    If I believe correct the fluid that I am meant to use should be AW-1? is Dexron III the equivalent?
    What should I do?
    Thank you
    Regular Member blue estate's Avatar
    oh well.. I tried..
    http://www.castrol.com/castrol/secti...tentId=7073092
    Put your reg in there and see what they suggest.. use this all the time at work
    Apr 2012
    London
    Thanks for the response, I typed in the reg, but it says refer to main dealer? which I know say to use GM 93 165 147 but I need to do a transmission flush so I need quite a bit and I get discounts at ECP so worth a try for an alternative.
    By the way, your estate looks fab
  1. Af40 Gearbox Limp Mode ( again )
    By viper8 in forum Engine & Drivetrain
    Last Post: 9th September 2012, 00:41
  2. Need an AF40 gearbox!
    By the_rocker in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2012, 17:47
  3. Automatic Gearbox
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 1st March 2011, 16:28
  4. Af40 auto gearbox loss of drive.
    By ricky1 in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2010, 21:57
vectra af40 auto box does not want to select drive when cold site:www.vectra-c.com
