Results 1 to 10 of 11
Thread: EGR Issues
    Merseyside
    Default EGR Issues
    Hi guys, although I no longer have my Signum, I have recently purchased a 2006 Saab 9-3 1.9 TID (150) Auto. It has 81k on the clock
    I've been having an EGR related issue (the usual hesitation at low revs) so I took it off, cleaned it and refitted it.
    On refitting it, there was still a bit of hesitancy so I stripped it off again and found the valve was still sticking slightly. After a further clean, and its now as clean as I can get it (although not as clean as I would like).
    Its going for a 400 mile motorway run next week which should help clear it out, but if the problem persists am I looking at a new EGR valve or are there any other issues that may be causing it? There are currently no fault codes either, so not sure where else to look.
    Merseyside
    PS - the above pic is the before pic - I've got an after pic but the file size iss too large to attach
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Quote Originally Posted by signum_1.9 View Post
    Does it hesitate when you demand power or hesitate while crusing?
    Merseyside
    When pulling away from a stop there is a hesitancy, but it seems fine on the motorway when I boot it - it seems to pick up fine then.
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    I too got the 93 tid 150 (manual) does the egr move freely after you cleaned if so have a read of my thread on cure for the flat spot hesitation fella
    Merseyside
    Quote Originally Posted by Richard.roberts View Post
    Both the solenoid and valve seem to move freely after the 2nd clean. I'll take a look at your other thread. Cheers
    Merseyside
    I've read your thread with interest..... I'm a little rusty on this engine as Its been 3 years since the Signum went - where can I locate that apparently troublesome part in your thread?
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    Its under the bonnet catch on the slam panel, if you follow the little vac pipes to the front of the engine you'll find it tucked underneath
    Merseyside
    Thanks for that - I'll take it for a run after the latest EGR clean in the morning - if I dont get any progress I'll try that fix - I'll also do the airbox mod and see what else is possibly lurking around in there.
    Sep 2011
    Caerphilly
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    No worries mucker let us know how it goes cheers
  1. A few issues..........
    By matt_6436 in forum Electrical & ICE (including SatNav)
    Last Post: 20th October 2012, 11:15
  2. GID issues
    By kensbey in forum Electrical & ICE (including SatNav)
    Last Post: 11th May 2011, 17:46
  3. Issues!
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2011, 01:13
  4. Would I have any issues with...
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2008, 19:07
  5. mp3 issues with cd 70
    By jeff_g in forum Electrical & ICE (including SatNav)
    Last Post: 6th June 2008, 22:27
