Thread: Timing/Cambelt Belt Change On 2.0 DTi
    Default Timing/Cambelt Belt Change On 2.0 DTi
    hello folks, long time no speak, anyway our taxi Vectra is approaching 70K miles, 2005 54 plate, 2.0 DTi 16v engine, just wondered what interval the timing/cambelt is due to be changed at, when should it be done, costs, etc.
    cheers
    Greg
    Regular Member Ross DTi 2.2's Avatar
    Münster, NRW, Germany
    It doesn't have a cambelt. Chain cam engine and no need for change.
    Regular Member simac's Avatar
    Wirral
    IIRC the chain's tension needs to be checked at 100k miles, worth checking though because I could be confused with a different car
    TBH I wasn't aware of that but it may indeed be true. GSi 3.2 is the man to ask about that, if you PM him, he'll sort you out.
    The tension is hydrailically adjusted throughout it's life using the pressure of the engine oil.. what they meany by inspecting it's tension is basically a link elongation check..I.E. how much more travel will the tensioner have left.. To be honest, if you've disassembled it far enough to view the chain, i'd whip another one on it.. not as cheap as a belt, but still realativley cheaper than a new engine..
  1. Replies: 25
    Last Post: 15th July 2012, 08:05
  2. Timing belt change
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 18th April 2012, 11:15
  3. Gsi timing belt change
    Last Post: 1st February 2012, 13:30
  4. cambelt/timing chain change
    By dgreensmith in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2009, 17:31
  5. Need to buy or borrow a Vx timing tool to change a 3.2 cambelt
    By muffking in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2006, 12:21
has my 05 vectra 2.0 dti got a timing belt
what milage should i do csm belt on vectra 2.0dti 54 plate
cam belt on vectra 2.0 dti 54
vectra c 2.0 dti tensioner adjustment
vectra 2.0 dti chain or belt
vectra 2.0 dti cambelt or chain
