Results 1 to 10 of 19
Thread: m.p.g
    Sep 2009
    birmingham
    Default m.p.g
    hi guys can anybody tell me what mpg my vectra c should be doing, its a 1.8 16v sxi 03 plate, ive got it worked out its doin 23 mpg, if this is below what it should be doing, how is best to get it to do the correct mpg?
    May 2011
    bispham, blackpool
    wow thats less than im getting in a gsi
    how are you driving flat out in every gear
    Regular Member John Bishop's Avatar
    Oct 2010
    Its even less than my v6
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Mine returns 41mpg, you should be getting much more than 23 mpg fella. The record is just over 51mpg for the 1.8 on this forum. EML on at all? Engine shaped light, Bottom right corner of the dashboard.
    Regular Member MURDO's Avatar
    Co.Clare, Ireland
    Vehicle : Opel Vectra GTS Sport Z18XE
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    wow. mines 1.8 16v too, but getting around 33. Thats very low considering fuel prices in the uk at the minute. How about recent service, i.e fuel, air, oil filters. any fuel treatment done...
    Sep 2009
    birmingham
    hi guys, dasArab no eml light mate, had a new mass airflow sensor fitted, 4mths ago. but the car has always seemed to drink alot of petrol, even before new maf, and ive had it 5yrs. i wish i was flat out everywhere 6009tristanb, i could understand 23mpg then what do you recommend ppl to get the mpg sorted?? much appreciated guys
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 Vtec
    Mileage : 64500
    Are you mainly town driving? Its had a set of plugs lately? Might be a knackered Lambda sensor. Might be worth doing a pedal test just in case the EML Light is faulty(it should light up when you turn the ignition to position 2).
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    my 1.8 duratech mondeo did 28 mpg and that was doing just under 2 miles to work.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 Vtec
    Mileage : 64500
    Sep 2009
    birmingham
    dasArab had a new set of plugs 12mths ago, and new air filter at the same time. its mainly A 2 B driving, when the eml light was on (before new maf) i had it put on a mach 2 machine, and the mechanic did say the rear lambda, was abit intermitten, so he changed it over with the front lambda, at they were both working fine, i have had a used catalyst fitted about 5mths ago, a new brain about 4mths ago, new gearbox and clutch 2wks ago, this car is startin to get on my nerves now, spent too much now though to get rid
