Thread: Different Pt No.s for 1.8VVT Camshaft Solenoids
    VIP-Member puppet's Avatar
    East Ayrshire
    8 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Default Different Pt No.s for 1.8VVT Camshaft Solenoids
    Does anybody know what the difference is between the two part numbers I have found for the camshaft solenoids on the 1.8VVT? (Z18XER engine)
    ie. Pt No. 12992408
    http://www.ebay.co.uk/itm/ws/eBayISA...vip=true&rt=nc
    and then there is Pt No. 55567050
    http://www.ebay.co.uk/itm/Vauxhall-C...item2c628b6d3c
    I know for a fact that the first number, 12992408, is what's in my own car (2006 SRi) as I took one out the other day to verify it.
    The first link states "Vectra C 2002+ & Signum with Z18XER engine code up to Chassis Number 71999999." My own chassis number is W0L0ZCF68********, so it would appear to tie in with this. I wondered if the two parts numbers were interchangeable or not though?
    East Ayrshire
    8 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Bump to the top!!
    Anybody know the difference between the 12992408 and 55567050 numbers that you can get for these solenoids?
    Jul 2013
    uk
    Vehicle : bin
    Trim : trim
    Engine : 123
    Quote Originally Posted by puppet View Post
    Bump to the top!!
    Is it not one Opel one Vauxhall p/n stuff again? Or maybe ones a revised version of the other
    East Ayrshire
    8 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Quote Originally Posted by timmy12345 View Post
    Could be either of those suggestions I daresay. I suppose the safest option would be to stick with the number I know is fitted, but wondered if it was ok to fit either type.
    Regular Member Hue Jarse's Avatar
    May 2012
    Farnborough, Hampshire
    Engine : 1.8 VVT (Z18XER)
    Year : 09
    VX EPC shows 12992408 as NLS and says "use 55567049". It only lists 55567050 under Zafira.
    Jul 2013
    uk
    Vehicle : bin
    Trim : trim
    Engine : 123
    Somewhere on the net - i forget where you can look up the VX OPEL equivs that may enlighten you
    East Ayrshire
    8 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Quote Originally Posted by Hue J**** View Post
    Cheers. I assume NLS means "No longer sold" or similar?
    May 2012
    Year : 09
    I've always assumed it's "no longer supplied" but I suppose it could be "sold" or "stocked". In any case you've got the right idea.
    May 2012
    UK
    I think 55567050 is the new version, they were updated due to problems!
    East Ayrshire
    8 Post(s)
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Quote Originally Posted by Chip View Post
    Cheers. Might well make sense, given the amount of folk on here that have had to change these.
  1. Z18XER (1.8VVT) Cam Solenoids
    By VVT-i-MATT in forum Engine & Drivetrain
    Last Post: 2nd February 2013, 10:35
  2. 1.8 VVTi Cam Actuator Solenoids
    By forde in forum Engine & Drivetrain
    Last Post: 24th January 2013, 14:05
  3. VVt Cam Phaser Solenoids
    By Ben50n in forum Engine & Drivetrain
    Last Post: 10th September 2012, 07:48
vectra 1.8 sri vvt camshaft solenoid
vectra c 1.8 camshaft solenoid symptoms
