Results 1 to 10 of 17
Thread: fitting resistors with leds
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default fitting resistors with leds
    are rhe resistors wired across the live and negative or into the live wire to the led thanks
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    I've always wired mine to the positive side unless anybody knows different.
    Hth
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I always do mine parallel to the the bulb
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    They replicate the load of a bulb so the bulb check system thinks there's a bulb fitted, so you wire them in parallel (positive to negative).
    Trim : improving
    Year : 06
    cheers chaps i'll go and start now then
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Is this so you can run any LEDs? What size resistors do you need?
    Dec 2011
    Seaham
    You could measure the resistance of the bulb and the LED and if you run them in parrallel you need to use this formulae.
    1/bulb resistance =1/LED +1/Resistor.
    If they are in series then
    Bulb resitance = LED + Resistor
    As to which way is best???
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    http://www.hids-direct.co.uk/categor...resistor-fixes
    These are the ones I use on mine and a couple of others have used on my advice. These are fine for an LED replacing a standard 501 sidelight bulb or in my case the LEDs in an angeleye headlight.
    http://www.hids-direct.co.uk/10w-res...-233-h6w-433c/
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I will be doing mine the way Ian has done his once i get them in the post lol
    Trim : improving
    Year : 06
    fiddly dont get me started..............2 1/2 hours to do the first side
    getting bulbs right way round was ok but fitting them not good seems like one goes in and one comes out resistor fitted across pos/neg
    and no bulb check showing will have to do other side sat. am weather permitting.
    cheers for all advice
  1. Replies: 21
    Last Post: 21st December 2012, 19:20
  2. fan blower cheap resistors
    By maldred in forum Electrical & ICE (including SatNav)
    Last Post: 19th August 2012, 20:43
  3. Load Resistors and LED in sidelights
    By RobW in forum Electrical & ICE (including SatNav)
    Last Post: 2nd February 2011, 01:15
  4. Power resistors to stop LED problem?
    Last Post: 17th September 2010, 19:11
  5. can resistors be bought separately for hid kit?
    By EURO G in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2008, 16:09
