Thread: battery wiring block next to battery 150tdci - HELP
    Mar 2012
    welshpool
    Default battery wiring block next to battery 150tdci - HELP
    can anyone tell me or do me a quick diagram to tell me which wire goes to where on the distribution block next to the battery.
    did an engine swap on my partners 150tdci and cant remember which wire goes to which...
    if anyone could help would be very greatful
    thanks
    james
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    You are aware that there are three connectors in the underhood module (UEC), engine bay fuse / relay box. - XE1, XE2, XE3.
    Between the three connectors, there could be as many as 100 wires.
    Unless you have TIS2000, Tis2Web or GlobalTis, you will struggle to get an accurate wiring diagram.
    It also depends upon what vehicle and model year the UEC is from, or going into. As Vauxhall made many changes.
    I spent a good day and a half listing the pin-outs for the UEC, and there are still many which I don't know.
    Mar 2012
    welshpool
    i do not mean the fuse box, there is a black distrabution box to the left of the batetry, a black plastic item with 4 posts for wires.
    Anyone got any idea wich wire goes where?
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Is this the part you were referring to?????
    http://www.vectra-c.com/forum/showth...fication-Query
    Nov 2010
    East Midlands
    Trim : design
    If its the box that attaches to the battery box - there are just two h/duty red wires connected through a large fuse
  1. battery and wiring advice
    By mungo1985 in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2012, 18:54
  2. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  3. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
  4. Dvd headunit, wiring to battery!!!
    By Jow20 in forum Vectra C / Signum Car Chat
    Last Post: 14th September 2010, 13:02
  5. 12v headlight strobes off a 6v HD block battery?!?!?!?
    By vectra_c_wannabe in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2009, 17:05
