Thread: Vectra C Estate Life (2008) Alarm Issues
    Sep 2009
    Belfast
    Default Vectra C Estate Life (2008) Alarm Issues
    Car Alarm goes off approx 5-mins from being set – this only started yesterday.
    I’ve looked over the forums and tried a few of the mentioned options.
    Checked each window quarter panel for breaks – Yes one was “open-circuited”
    I removed the two cables and shorted out the contacts – alarm still goes off after 5mins.
    I then removed the second set of contacts (just in case) on the other window and shorted these out – the alarm still goes off.
    Unsure if there are any contacts within the rear window – can someone advise were they are and how to get to these.
    I’ve now removed fuses 21 & 23 – the alarm no longer sounds but I think this has disabled the alarm…..
    I’ve no Tech2 equipment or alarms data on my dash (basis car only)
    Can anyone shed any light on this.
    Nov 2009
    Warwickshire
    Do you have a tow bar? I had the same problem with my estate - when it was still under warranty - Vx electrician found cause was a short off the tow bar wiring connection into the loom.
    Sep 2009
    Belfast
    Sorry No towbar or any other non-standard option.
    Regular Member John Bishop's Avatar
    Oct 2010
    Read somewhere that the rear demister on the estate acts as a sensor for the alarm just like the rear side windows. Would imagine you would need to take the trim off the tailgate to get to the connections.
    Sep 2009
    Belfast
    I was thinking something similar - unsure how to take of all the trim without beaking it. Does anynow now are the cables located at the bottom of the window need the door lock.
    Nov 2009
    Warwickshire
    You could eliminate it by pulling the heated rear window fuse off the rear fuse box.
    Sep 2009
    Belfast
    didn't think of that - I'll give it a try
    Sep 2009
    Belfast
    no difference removing fuse 4. I've removed fuse 21 and put back fuse 23. I don't think the alarm will now operate - can anyone confirm.
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    have you tried pressing the running man button to disable the ultrasonics when you lock the car ??
    this is the easiest way of eliminating a fault within the sensors .
    Sep 2009
    Belfast
    Yes, I done this first and the alarm still went off.
  1. vectra c estate 07 alarm sounder
    By sausaged in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2013, 16:52
  2. MY2006 55-Plate Vectra CDTI 150 Estate Life
    By AntSSSS in forum Vehicle Diaries
    Last Post: 31st May 2012, 08:33
  3. Alarm problem-06 vectra estate
    By graeme900 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th July 2010, 09:31
  4. Vectra Life 1.8 Saloon alarm problem
    By greieras in forum Vectra C / Signum Troubleshooting
    Last Post: 26th February 2009, 16:59
  5. 05 Vectra Estate Life 1.9 CDTI 120 Spanner light keeps coming on
    By themagpie in forum Engine & Drivetrain
    Last Post: 23rd March 2008, 17:23
