Thread: (error codes)
    Aug 2010
    york
    Default (error codes)
    HI,
    can anyone explain this error code.
    B3114-00 remote key 1 not syncronised.
    U2103 no communication with can-bus ( HIGH SPEED )
    Any help appreciated
    Aug 2010
    york
    it also had error codes
    C1523- system voltage high voltage
    (07) - not present
    C1526 - motor malfunction
    (00) - not present
    C1550 - replace ECU
    (37) not present
    U2105 - can-bus no communication with ECM
    (00) - not present
    U2105- can-bus ECM message range/performance
    (71) - not present
    U2139 - can-bus no communication with steering column module
    (00) - not present
    Thanks ,,
    Jul 2010
    Warrington / Liverpool
    I think the first one means you havent used your spare key for a while...
    I cant help but feel I had the other one when mine was done, didnt read much into it because I thought it was because the engine was not running.
    Just a guess, sure someone will be along to help shortly
    Aug 2010
    york
    yeah only ever used spare key once or twice in years of owning car ( its a 2003 2.2 DTI SRI )
    Jul 2010
    I think if you just use the spare key again it synchronises it, shouldnt cause any issues anyway as far as i'm aware lol...
    Are you having trouble with it or just checked the codes?
    Aug 2010
    york
    Car running great at mo...just checking codes,just curious if anything major.....
    Aug 2010
    york
    Ive cleared all codes and will see if anything comes back .
  1. error codes
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2012, 20:33
  2. 3.2 error codes help please
    By gibsonk in forum Engine & Drivetrain
    Last Post: 28th January 2012, 13:03
  3. 3 error codes
    By Hydravox in forum Engine & Drivetrain
    Last Post: 20th April 2011, 12:14
  4. error codes
    By bower in forum Engine & Drivetrain
    Last Post: 7th November 2010, 23:01
  5. error codes
    By delboy2028 in forum Engine & Drivetrain
    Last Post: 29th June 2010, 13:27
b3114-00
cod b3114-00
b3114-00 vectra c
b3114 00 error
Vauxhall B3114
